Old 14-01-10, 07:17 PM   #21
Filipe M.
Default Re: Firefox irritations
Chrome.
Old 14-01-10, 07:27 PM   #22
Ed
Originally Posted by Jabba View Post
Ed,
What OS are you using? Windows XP, Vista, Linux of some sort?
If Windows then I have an alternative, slightly radical solution for you....... IE8
I use XP - at home, Home, and at work, Pro.
IE8? Surrender!
Old 14-01-10, 07:29 PM   #23
Stu
Trinity
Stu's Avatar
hahaha, Opera FTW.
Try it mate, its like Firefox....but better.
No!
Originally Posted by Filipe M. View Post
Chrome.
Maybe
3.5.7 is fine lot's of them ''''''
Old 14-01-10, 07:32 PM   #24
Dave20046
Dave20046's Avatar
Not got a sticky key on your keyboard or 'function' enabled have you?
Old 14-01-10, 07:41 PM   #25
Ed
Nossir!!!!!!!! So Stu is aiding and abetting beabert...
*******s, both of you
Old 14-01-10, 07:42 PM   #26
Dave20046
Dave20046's Avatar
It only does it for me if I haven't clicked my cursor in the field (box where you type).
Old 15-01-10, 01:14 AM   #27
madcockney
The following relates to FF 3.5.7.
The ' to open the quick find bar is a built in FF function. The other problems could be a corrupted profile, but see the last para below. This profile can be deleted and FF will recreate, but be aware that it will return to the default configurations so any settings that you have changed will not be saved and from memory this also applies to addons. It may be worth you backing up the profile so that you can copy items back into the newly created one if required, or you could rename it I suppose.
in XP >Run > %appdata%\mozilla\firefox\profiles\
One other thing check that you have the correct permissions on the profile folder. The user should have special permissions and in the advanced tab should full control of this folder only, and Creator owner full control of sub folders and files. If not it maybe that you cannot write to the profile.
madcockney is offline   Reply With Quote
Old 15-01-10, 11:14 AM   #28
Ed
...mmm-kay... Thanks for that - I'm not sure what all that means, it's not doing it today, so I don't feel like throwing the 'puter out the window. (Yet)
Old 16-01-10, 12:58 AM   #29
madcockney
I should have been a bit clearer:
Go to Run on the start menu, and type in: %appdata%\mozilla\firefox\profiles\ then hit enter/return. This should display the FF profile folder. Right click on the folder and select properties and then the security tab, followed by selecting the advance button. Then follow the permissions mentioned in my previous posting.
Should this not work then backup the folder, and either rename the original or deleted it, when a new profile folder will be created when FF starts.
Old 16-01-10, 09:32 AM   #30
mr.anderson
mr.anderson's Avatar
Chrome.
Chrome. +1
mr.anderson is offline   Reply With Quote
Firefox new tab Stu Idle Banter 16 19-06-09 10:03 AM
who has upgraded to firefox 3 timwilky Idle Banter 32 18-06-08 03:51 PM
firefox help Wideboy Idle Banter 8 19-12-07 01:05 PM
Firefox II Razor Idle Banter 21 06-12-06 12:25 AM
Yet another reason not to use Firefox jonboy Idle Banter 4 27-03-06 10:32 PM
