#21 | ||||
*Assuming there isn't lots that is, they do not last well. Quote:
If your lifter is perfectly new and unworn you can adjust it like it says in the manual, it'll be about right. In any other circumstance follow my guide - when there's any wear at all in the lifter anything other than fully down will waste lift and at least make it harder to achieve a useable adjustment. Quote:
Understanding what's happening when the lifter is other than entirely unworn means it won't function right unless the 'revised' information is followed. I have done this a lot and I assure you this is good, practical information that comes from experience with this and other Suzukis that use either the same or a very similar assembly. And Again! Quote:
#22 |
So how can I tell if my lifter is in good working order and I should go with one method or the other?
#23 |
Slacken the cable off, then adjust the lifter screw to no slack, (but only just, it musn't be screwed in at all - just touching the end of the pushrod). If the lifter arm moves up and down more than a tiny bit - it's worn. In practice more than about 4-5mm and it can get difficult to get the adjustment right - but this is heavily dependant on wear in the clutch assembly itself.
#24 | |
#25 |
Replaced my worm drive @ 45k as was completely knackered , made a huge difference and could get perfect adjustment easy after
Lovely light clutch Cheers Steveg
ex - red sv650s 06 reg Now Triumph sprint 1050 ABS 05 Reg AKA Papa Smurf ![]() |
#26 |
ok..
See ive just done mine the Sid Squid way, yet when i did this it was no good. Had to go and undo the lock nut and back out the adjuster another 1/8 of a turn. By adjusting the cable at the worm drive end after adjusting the worm drive correctly I was now appearing to be making contact with no lever pull. This is what I was getting at before ![]() ![]() Last edited by noob-saibot; 03-02-10 at 08:07 PM. |
#27 |
#28 |
#29 |
£33 quid + VAT
Cheers Steve
#30 |
i think i need to adjust my clutch too. It seems to be grind when going from 1st to 2nd like its not fully disengaged. from 2nd onwards is find though
SV Clutch Worm Drive (bearings) | Dave20046 | SV Talk, Tuning & Tweaking | 11 | 25-11-09 09:36 PM |
Clutch/Worm drive problem | swinging_simian | SV Talk, Tuning & Tweaking | 2 | 05-08-09 01:06 PM |
Clutch worm gear | cammy | SV Talk, Tuning & Tweaking | 3 | 02-08-09 07:23 PM |
Worm Drive | tonybmw92 | SV Talk, Tuning & Tweaking | 15 | 15-08-08 08:12 PM |
Clutch worm drive thing for '00 curvy | Ter | Stuff Wanted | 1 | 16-01-07 04:00 PM |
