Old 08-02-10, 06:59 PM   #21
xXBADGERXx
Default Re: Slow rev decrease
Food for thought isn`t it . I have left mine alone on purpose , when I fit the clamp and it cures/doesn`t cure it ...... we`ll know if I`m barking up the wrong tree
Old 08-02-10, 08:49 PM   #22
beabert
Originally Posted by 5hort5 View Post
That's interesting as I have swapped the CCC race can back to the standard can but wouldn't have expected that to cause the issue.
ahhh ha.
The pilot jet is sometimes changed when a more free flowing can is added, maybe your jet is the wrong size now 5short5, check they are all standard sizes.
Old 08-02-10, 09:53 PM   #23
5hort5
Anyone know what the default number of turns out it is for pilot screws on the carbs? Is it 2.5?
5hort5 is offline   Reply With Quote
Old 08-02-10, 09:56 PM   #24
5hort5
ignore that - found it at the front of the chapter in haynes
Old 08-02-10, 11:49 PM   #25
Originally Posted by beabert View Post
ahhh ha.
Rarely. I have not heard of anyone changing pilot to anything but 17.5 (mikuni size) which is the stock size for UK bikes. Some US ones get 15 size.
Pilot screws between 2.5-3 turns but these will just do some crazy stuff if you have an air leak
Old 28-02-10, 07:52 PM   #26
5hort5
we i had time today to have another look and after taking the carbs off and refitting them they had the same issue so I dusted of the 5 quid fleebay set and stuck them on, interesting they work rather well. I just reset the pilot screws and set the balance screw to the same as the other carbs and it's not perfect but close and a load better than the ones I had so I'll stick with these now
SV is too slow. Get a C50 captainsmelly Idle Banter 11 01-06-09 07:45 PM
Slow?? SV PILOT Bikes - Talk & Issues 20 14-05-08 11:25 PM
You know you are having a slow day when..... SoulKiss Idle Banter 13 01-03-08 10:56 AM
98/99 to slow andy marriner SV Talk, Tuning & Tweaking 20 08-11-04 11:52 PM
