Old 07-02-10, 07:37 PM   #21
Default Re: LED indicators flashing fast.
i had this problem and couldnt be arsed messing so just put the normal indys on (they make great crash bungs)
Old 07-02-10, 08:22 PM   #22
SuzukiNess
lol just the reason i replacing mine... been crash bunged too many times (4 times in the last year - and only 1 of those 4 was my stupidty!) so i was thinking along the lines if they smaller they wouldnt be broken but the issues with resistors and relays blah blah i think i should just revert back to normal ones..
Old 07-02-10, 08:34 PM   #23
Jayneflakes
Jayneflakes's Avatar
It is irritating when things don't work just so, but once it is sorted you wont have to deal with it again, until you change the lamps due to them getting broken... again!
Good luck and don't give up.
Jayne you're a Pussy Magnet
Old 07-02-10, 08:40 PM   #24
I moved the indicators to a different part of the snowplough and have never broken them in crashes.
Old 07-02-10, 09:01 PM   #25
boot
Default Re: LED's on a 2007 Pointy - help needed pls
YC, is this LED only? Or would it work for a mixed bag? I have led indicators on the front but standard rears. Thought of getting some standard fit BA9S led bulbs for the rear as I need to replace my rear indicators anyway, as they're corroded to buggery, and at about £10 per pair replacement for basic ones, it'd be much cheaper than getting led indicators.
I am a cheapskate.
Old 07-02-10, 10:54 PM   #26
12V 10W max... says it right there. Normal indicator bulbs are 21W IIRC
If you want more power use the LED flasher to trigger a normal relay, might work, might need 5W of ballast between the relay output and ground though.
Old 08-02-10, 11:06 AM   #27
phi-dan
phi-dan's Avatar
or there's something like this aftermarket unit which swaps right in
Note: not got one, just offering up the option
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 08-03-10, 07:14 PM   #28
cbay
cbay's Avatar
I bought what phi-dan recommended LINKY
That means no cutting etc. Like it! Wonder when it will arrive?
Indicators flashing too fast... Gnome SV Talk, Tuning & Tweaking 17 14-02-18 06:50 PM
Indicators Flashing Fast Mr_Chin SV Talk, Tuning & Tweaking 6 28-08-09 04:41 AM
Replaced indicators - one side only flashing fast CraigBruce SV Talk, Tuning & Tweaking 6 10-07-09 10:54 AM
Fast flashing indicators - what resistor do I need? muffles SV Talk, Tuning & Tweaking 7 11-09-06 12:15 PM
Fast flashing indicators!! JimPSV SV Talk, Tuning & Tweaking 6 05-09-06 08:08 AM
