Old 26-02-10, 10:10 PM   #21
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: No handed kneedown, is it possible?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-02-10, 11:09 PM   #22
Ta da
Sylvain Guintoli
Old 26-02-10, 11:14 PM   #23
sinbad
Erm does no handed mean 1 handed?
Old 26-02-10, 11:32 PM   #24
I doubt its possible. I reckon past about this point and you'd be falling off.
Old 26-02-10, 11:48 PM   #25
Berlin
[QUOTE=punyXpress;2195903]
Originally Posted by svjonesy View Post
But bikes need rider input to get round a bend, in particular counter steering, and as you can see if you watch bike racing when there is no ride input (i.e. when someone comes off) a bikes natural tendendcy is to sit up right and carry on in a straight line therefore if you have no hands on the handlebars you would have to choices:
Not quite - you only need the right amount of throttle to balance the lean & the turning circle. Less & you fall inwards, more & you do the other thing. Counter steering only initiates the turn and is only used again to alter it.
Technically not true Dave. A bike needs countersteering to make it lean over but once there, the force doesn't need to be continually applied. It is applied again at the exit of the corner, in the opposite direction, to make the bike stand up again.
C
Old 26-02-10, 11:53 PM   #26
punyXpress
punyXpress's Avatar
[QUOTE=Berlin;2196017]
C
You're getting tired or emotional, Carl.
'tis what I said : Counter steering only initiates the turn and is only used again to alter it.
i.e. alter it for either more OR less lean.
Now: Street Triple R
Old 26-02-10, 11:54 PM   #27
Berlin
Ok, I'm an idiot.
Now learn to quote properly!!
C
Old 27-02-10, 12:23 AM   #28
lukemillar
Problem is not so much the steering or lean but the throttle. As soon as you let go, the weight will transfer forward and unsettle the bike. I doubt it would stand upright, probably lean a little more suddenly lowside from the bike pitching forwards!
You could do it if you had a throttle elsewhere on the bike i.e on a peg! otherwise I'd say it can't be done. Even on a downhill bend, the back torque from the engine will slow you down. Maybe if you had a throttlemeister and rode around in a circle. However, that strays into very "ghey" riding territory.
Old 27-02-10, 12:55 AM   #29
ophic
ophic's Avatar
Is that davepreston immediately prior to becoming one with a 4x4?
Silver SV650SK3, Fuel exhaust
Old 27-02-10, 09:38 AM   #30
Red Herring
Red Herring's Avatar
OK, not wishing to brag but yes it can be done, quite easily. The trick is having the room to make sure you do it in a controlled fashion. We used to carry out various exercises to teach/develop balance and handling technique and we used the skid pan at FHQ. The knee down bit really just came about because it's something most bikers want to try at least once and with the facilities it would have been rude not to.
First we turn the idle up, and I mean really up, about 3,500 rpm. then it's just a case of riding around in third gear and setting the bike up in a circle (which isn't that easy when the revs are set that high, start quicker then gently slow until running around without touching the throttle) which you then gently tighten until you reach the desired angle of bank (peg just off the ground is nice). This is where the exercise started because the idea was to position yourself on the bike so that you required minimum steering input, and eventually with a little practice it was so little you could take both hands off the bars. Not all of us wanted to do it knee down, but some off us certainly did just for bragging rights!
Don't try this on the road thought folks. The whole idea of the exercise was to demonstrate just how much we use the throttle to balance the bike and how once you don't have that option you need to use steering instead. On the road this is just not a good idea.
got my kneedown at last! Boo yah! Paul the 6th Photos 13 22-06-09 02:18 AM
Kneedown: a cautionary tale Zombie Jesus Idle Banter 6 10-05-09 11:26 PM
How 2 get ya kneedown - the vid Blue_SV650S Idle Banter 48 22-04-08 02:19 PM
How often do you get your kneedown?? (on the road only). Blue_SV650S Bikes - Talk & Issues 63 17-10-07 07:33 PM
