Old 24-03-10, 05:25 PM   #21
Dr.Tom
Default Re: Correct oil for GSXR front end?
Do you just need a recommended setting, or do you need a walk through of how to set it?
Recommended settings and a rough guide. I done it before but it was on an enduro machine
Old 24-03-10, 05:39 PM   #22
fastdruid
fastdruid's Avatar
Remove springs, take a piece of wire, measure the 'air gap' on this and bend at 90degrees so the 'air gap' is measured from the end to the bend. Place this so it dangles into the fork leg, fully compress the leg and pour in the oil until it just touches the end of the wire. Remove wire and 'pump' the leg about 5 times (being careful that some design of forks will spray oil out of the top!), replace the wire and top up again. Repeat until the oil level does not drop.
Put in springs and for future reference measure the air gap again, then slide the fork leg up and fit caps.
Druid
Old 24-03-10, 05:40 PM   #23
fastdruid
fastdruid's Avatar
Here are standard heights
Druid
Old 24-03-10, 05:54 PM   #24
pumping fork leg like that won't work, you need to pump the rebound rod up and down to get the air out of the cartridge.
Old 24-03-10, 05:59 PM   #25
fastdruid
fastdruid's Avatar
You are totally right, I'm getting myself confused between RWU and USD.
Druid
Old 24-03-10, 06:01 PM   #26
No you're not.
You're getting yourself confused between damper rod and cartridge.
Old 24-03-10, 06:45 PM   #27
Dr.Tom
Just for everyones info the oil capacity for each fork leg (as I now found outt) is 509ml
Old 24-03-10, 07:14 PM   #28
fastdruid
fastdruid's Avatar
No you're not.
No I'm not, I pump them while holding the damper rod at the top. NC30 and similar type design I loosely screw the cap back on first as it prevents oil squirting in my face.
Yes but you cannot rely on that as you may have some oil left in there.
Druid
Old 24-03-10, 07:49 PM   #29
Ahhh, AFAIK the NC30 uses a recirc type adjuster so oil is designed to shoot out the top rather than just bypassing piston
Old 24-03-10, 08:16 PM   #30
Dr.Tom
Right Ive added 509ml of 5WT Rock Oil and I have an oil level of 155ml when I put my steel rule into the bottom of the shock. Ive followed the GSXR service manual as best as I could so do I take out some oil to get my 101mm reading???
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
