#21 |
Ram air dont help until you are well above 100mph. Even then I cant see it making that much difference! Only real benefit is clean cool air from front of bike... but then it will eat a lot of flies. My air box had a nice collection :'(
#22 | |
Trinity
i.e. a non ram air bike suffering negative pressure in the airbox as the engine sucks in air faster than it can be replaced, compared to a slightly positive air pressure in the air box of ram air bikes from about 85 mph (easily achievable by an SV ![]() |
#23 |
A the end of the day Suzuki spent money researching air flow on their bikes for a reason.
#24 |
Trinity
#25 | |
They didn't on the SV. They went for the simplest possible solution to the nosie regs which is to put a massively restrictive snorkel in the intake.
#26 | |
For that money you are fitting flatslide carbs which do not use airbox, so the "airbox pressure" then is the stagnation pressure WRT the bike. Fair enough behind fairing/rad/whatever lump is in flow... you will have region of reduced pressure. BUT nowhere near the reduction of highly strangled stock filter as well as the structural issue. Look at figures they get, h*nda @ 28mb. ZRX low at -27mb. As I see it that's the honda with bigger scoops than the cylinder head demands flow, and the ZRX with a poor airbox design. And still c5% difference if that depending on atmospheric pressure between tests.
#27 |
#28 |
See, there is and advantage to ram air, I heard once about an RGV250 rider who hit a pigeon, went straight through the fairing and knocked him off! I'd prefer the ram air to take a munch!
Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#29 |
You would not believe it mate, amazing sight... the mesh thing on the ram tube was stuck to the poor thing in the air box, but in process it had shredded most of the bird. Amazing how much kinetic energy there is in 150mph
#30 | |
![]() and looking at the space there is, theres no way i could feed a big enough tube from the air box to the front of the bike so will just make some 17mm tank risers but still would be intresting to see a sv with it vs without it |
carbon fibre cans | baz6552 | SV Talk, Tuning & Tweaking | 2 | 01-02-10 10:52 PM |
Carbon fibre fairing | Little Rich | Stuff Wanted | 0 | 25-10-06 01:04 PM |
can i drill carbon fibre? | adamfool | Idle Banter | 15 | 04-05-06 10:47 PM |
Carbon Fibre. | Peter Henry | Bikes - Talk & Issues | 21 | 03-05-05 11:25 AM |
oval carbon fibre can | shoey2988 | Exhausts | 1 | 17-09-04 05:26 PM |
