#21 |
A good one i've used before is Hylomar also used this one from Halfords, you get a nice little nozzle to apply it with as well.
http://www.halfords.com/webapp/wcs/s...egoryId_165691 I haven't used sealant on this cover before so I would approach with caution, unless some one can come along with some more advice! Also as the water i pressurised I would be worried about water in the oil not oil in the water, IF you do reuse the gasket and use sealant I would keep an eye on your water levels. After buying the sealant and the possibility of it leaking £9.33 for a new gasket is not too bad. Cheers, Pete |
#22 | |
#23 |
(1) I think you are calling it the clutch actuator. It's the bit that spins round and goes in/out as you pull the clutch.
(2) Use wd40 or something similar. Best to squirt in then leave for a bit, cloth out, then squirt a bit more in to clean any little bits out. Don't bother clothing after this just grease. (3) Then pack any type of grease in there car, mountain bike.(long as it's not hair grease) |
#24 | |
Do the right thing and buy another gasket. you dont want to have to deal with a coolant leak into the clutch/sump/engine do you?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#25 | |
#26 | |
#27 |
Haha reminder: muz check the dates of the posts!
starter clutch replacement. | bigoverdraught | SV Talk, Tuning & Tweaking | 3 | 07-04-10 10:18 PM |
Clutch lever replacement | stophel | SV Talk, Tuning & Tweaking | 1 | 23-11-09 12:29 PM |
Replacement clutch springs? | Grinch | SV Talk, Tuning & Tweaking | 8 | 20-09-09 03:18 PM |
Clutch replacement, easy enough? | ELR4ever | SV Talk, Tuning & Tweaking | 12 | 21-12-07 03:17 PM |
Clutch Cable replacement. | dmracing | SV Talk, Tuning & Tweaking | 1 | 21-10-07 11:45 AM |
