Old 29-04-10, 05:45 PM   #21
Default Re: felt abit unstable at high speed
i had the same prob, was the front end too soft. cpl clicks on the rebound side and all was fine.
Old 29-04-10, 10:47 PM   #22
timwilky
timwilky's Avatar
Originally Posted by hindle8907 View Post
maybe haha.... take it that was you in the beemer.
it was a bit nippy and i couldnt find my big jacket...
Has he been plumbing again?
Not Grumpy, opinionated.
Old 29-04-10, 11:36 PM   #23
DavieSV
DavieSV's Avatar
i only had new tyres fitted about 1000 miles ago. do they not balance them then ?
They say they do
but if you dont see them do it...
My mate had a set fitted to loose wheels of his fazer, when he had them done, I put them on my balancing stand and they were a mile out. I don't think he even took the weights off from before
DavieSV is offline   Reply With Quote
Old 30-04-10, 03:17 PM   #24
Default Re: GSXR front end fitted - instability at high speeds
I would say to check that you haven't over tightened the stem as this can cause steering wobble
Old 07-05-10, 06:55 AM   #25
hindle8907
hindle8907's Avatar
just to add to this, i checked the wheel weights last night and on the left hand side there is a x2 5g and x1 10g and on the right side there is x1 5g and x1 10g ?
surely this should be the same ?
Old 07-05-10, 08:46 AM   #26
Go through everything
tyre pressures, make sure they're correct
steering head bearings make sure there's no play
check all the adjustments are set the same on both forks
check that stem nut has been torqued down properly
But get your wheel balanaced first
Old 07-05-10, 08:53 AM   #27
hindle8907
hindle8907's Avatar
tyre pressures, make sure they're correct - Done this is OK
steering head bearings make sure there's no play - How ?
check all the adjustments are set the same on both forks - Seems to be but not sure if set-up right for my weight though
check that stem nut has been torqued down properly - Don't have the tools
Will it not be the wheel missing wheel weight ?
can I not just add a 5g to match the other side.
Old 07-05-10, 09:01 AM   #28
tyre pressures, make sure they're correct - Done this is OK - good
steering head bearings make sure there's no play - How - raise the front end off the ground if you can and push/pull forks to see if there's any play. Should be solid, but free to turn
check all the adjustments are set the same on both forks - Seems to be but not sure if set-up right for my weight though - ok
check that stem nut has been torqued down properly - Don't have the tools - just make sure its tight then
can I not just add a 5g to match the other side - at 90mph you want to be sure that you're wheel is correctly balanced, just addding 5grms because you think its missing is not a sound and safe method of balancing a wheel
So get a garage with the correct equipment to balance it
Old 07-05-10, 09:18 AM   #29
barwel1992
to check play i head bearings
you can lift the front of the bike (no weight on the front) and turn the forks side to side see if they notch at all if they do they are buggerd, to check for play then pull the stanchion towards you then towards the bike "back an forth" to see if there's any clicks coming from the head bearings, you should be able to hear/feel them if not the bearings are most likley ok
or hold the front brake on and push the bike back and forth you will hear a click noise if there is play in the bearings or get some one to put there hands on top of the stem nut and see if they can feel a click while you rock the bike
Old 07-05-10, 09:23 AM   #30
hindle8907
hindle8907's Avatar
should the weights be the same on both sides ?
new gsxr shocker fitted. tommy-d SV Talk, Tuning & Tweaking 4 18-02-10 09:10 AM
Front suspension noise and instability - advice please. Tian SV Talk, Tuning & Tweaking 10 08-01-10 08:03 PM
High Level system fitted mister c Photos 34 27-05-09 02:58 PM
Riding at 'high' speeds? Magnum Bikes - Talk & Issues 74 21-02-09 01:24 AM
Project GSXR front end - FITTED WITH PICS PAGE 2 -56K BEWARE Khewett SV Talk, Tuning & Tweaking 32 05-06-06 09:25 AM
