Old 18-05-10, 09:31 AM   #21
Default Re: Which Alram System
Maybe they should ride their bikes once every 1/4?
That would probably cure the problem! Neither of them does more than 2k a year (and i've done that since march)
Old 18-05-10, 09:37 AM   #22
AndyBrad
no when you set it off and then put it in service mode it gives you a series of beeps to tell you like 20 seconds, then 3 beeps. which is what we were having. If you go into service mode and back out again and start the bike it clears it so its only 1 beep. that 1 beep is then half the volume of the 3 beeps!!
Old 18-05-10, 12:08 PM   #23
Miss_Undaztood
Default Re: Which Alarm System
Originally Posted by I'm_a_Newbie View Post
Now I have my new bike I am after a Cat 1 alarm system.
How about getting an Alphadot kit ?
Only £25 quid, not sure how much of a real deterant they are tho.
Old 18-05-10, 12:10 PM   #24
None!
When is last time you checked for alphadots when buying used fairings? Plus I think suzukis get them as standard anyway, not that I've ever heard of them helping much.
Old 18-05-10, 12:27 PM   #25
sniff
sniff's Avatar
I've got a Cyclone alarm, had them on last three bikes. cost £20 and very good, loud and not anoying like most of the rest. Has also got remote start if you want to wire that in. With engine cut out with a range of 100 meters. So if you see someone riding off with it you can disable it.
sniff is offline   Reply With Quote
Old 18-05-10, 01:36 PM   #26
rictus01
rictus01's Avatar
None!
datatag is more effective, I normal mark all the panels on the inside apart from one where it's clearly visable (rear light normally), and I do take notice of datatagged parts.
Cheers Mark.
Old 18-05-10, 02:54 PM   #27
TheRamJam
TheRamJam's Avatar
I have a Xena XN14 Disc Lock Alarm with built in 110dB alarm.
Cost me 60 green ones and does the job
Previous: Suzuki SV650S K9 - Sold
Suzuki GSXR1000 K8 - Wrote Aff
Honda Fireblade RR-9 - Sold
Yamaha MT 10 - Sold
Current Bike: Aprilia Tuono V4 Factory
TheRamJam is offline   Reply With Quote
Old 18-05-10, 03:32 PM   #28
gettin2dizzy
Datatool are alright. Had a system 4 (£350) and now a system 3 (fitted by dealer).
The 4 was faultless, and the 3 more than adequate. I personally love them as I can just hop in to a shop no problemos. Not only is it a theft deterrent, but it stops kids from climbing over it as you walk around the supermarket. As for battery useage, I can start my bike after 5 weeks no problemo.
M4 99 - 02 system/or can drag Stuff Wanted 0 21-03-10 04:11 PM
Exhaust system MCN_LiamM Mini-Twins 5 03-12-08 12:55 PM
ABS system Dutchman SV Talk, Tuning & Tweaking 4 29-06-08 05:17 PM
Akrapovic full system or yoshi full system ? ? ? hall13uk Exhausts 40 15-08-07 11:44 PM
Map system Baph Bikes - Talk & Issues 2 28-02-07 12:14 PM
