Old 07-07-10, 06:02 AM   #21
Speedy Claire
Default Re: Renthal Bar 998cc.com Conversion
As far as i`m aware Mike didn`t have any problems with my clutch cable either?
Old 07-07-10, 06:31 AM   #22
I can confirm, i have had no issues with the clutch, i did think it was tiny bit tight at first but re-routing it more effeciently sorts it out.
I even think you could get away with the throttles if you re-routed them better.
Old 07-07-10, 09:41 AM   #23
Luckypants
Luckypants's Avatar
Nope no problem with the clutch cable, it needed re-routing but it all works fine. There is no issue with clutch slip on full lock either. I have been told that the clutch cable for the naked SV is slightly longer than the S model's, (I need to confirm this but they certainly have different part numbers) so you could replace the clutch cable with one from a naked.
Old 07-07-10, 09:49 AM   #24
danf1234
To Specialone and Lucky -
Were yours both fitted to an S?
Old 07-07-10, 10:14 AM   #25
Luckypants
Luckypants's Avatar
YES for both. That's the point of the kit isn't it.
Old 07-07-10, 10:29 AM   #26
danf1234
Doh - Yes I am today's Div.
Old 07-07-10, 11:41 AM   #27
madness
The standard clutch cable does work fine, but it's not perfect. Route it one way and it rubs on the yoke on full R/H lock, route it the other way and it kinks a bit at the end of the metal tube on full L/H lock. Most people would be happy with it, but I'm not most people.
Old 07-07-10, 03:09 PM   #28
TopCat69
So the question arises, would I be better just buying a clutch cable for a naked or a V-Strom "just in case" I have any problems with the routing etc?
It's only about a tenner. If it's not needed in the end, then it's there for emergencies or I could resell it.
It also may cut down on the liberal and prolific use of multiple conjoined expletives which is known to occur if I'm having problems when working on the bike.
Old 07-07-10, 03:28 PM   #29
Speedy Claire
Well I haven`t fitted the kit but why waste money on buying something you`re not going to need?
Old 07-07-10, 03:39 PM   #30
danf1234
I was wondering that?
998CC.com Forum code Matts-Yokes SV Talk, Tuning & Tweaking 17 28-07-10 11:24 AM
Renthal Bar conversion BomBalong SV Talk, Tuning & Tweaking 5 05-07-10 04:35 PM
www.998cc.co.uk risers Paul1984 Bikes - Talk & Issues 15 26-06-10 06:46 AM
998cc.com comfort kit maff Idle Banter 0 04-11-09 11:24 AM
re svs renthal conversion kit markmoto SV Talk, Tuning & Tweaking 1 11-07-09 08:16 PM
