Old 19-07-10, 09:29 PM   #21
Dave20046
Dave20046's Avatar
Default Re: brake judder ?
did you remove the paint from the wheel?
Old 19-07-10, 09:31 PM   #22
barwel1992
yup done that
Old 20-07-10, 11:41 AM   #23
Lozzo
If anyone else is suffering from warped discs, they can be straightened by the good people at Hagon, the shock makers, in Hainault, Essex.
I've had loads done by them over the years and they are a damn sight cheaper than buying new discs.
Old 20-07-10, 12:25 PM   #24
dyzio
dyzio's Avatar
Have you tried to clean the rotor buttons? My Ape suffers from this from time to time.
But this is probably not much help as you say there is no lever pulsing at low speed :/
Old 20-07-10, 01:05 PM   #25
G
Do you mean the washers on the floating discs? Mine get full of dirt etc and so when the discs heat up and expand they have no where to really go.
6.67300 × 10-11 m3 kg-1 s-2
Old 20-07-10, 01:14 PM   #26
barwel1992
will get some brake cleaner later and give them a good clean with a tooth brush and clener
cheers
Old 20-07-10, 01:19 PM   #27
dyzio
dyzio's Avatar
Yep, when they get dirty the disc cannot float and the lever starts pulsing. Common with Aprilia's discs.
Old 20-07-10, 01:23 PM   #28
barwel1992
^ just to make it known i dont have aprilia discs, they are triumph 595 disc's and triumph wheel, dosnt mean that they wouldent do the same though
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Seem to have a judder from the front... Idea's? ThEGr33k Bikes - Talk & Issues 25 06-06-09 01:11 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
Brake Judder. niccollotto SV Talk, Tuning & Tweaking 1 22-10-08 10:06 AM
Front Wheel Judder dmracing SV Talk, Tuning & Tweaking 6 14-07-08 11:30 AM
