#21 |
#22 | |
#23 |
#24 |
Mine gets ridden to the Jetwash and blasted when I can't see what colour it's meant to be. Just keep the high pressure hose away from bearings and don't get too close to decals.
I don't see the point in detailing bikes or spunking huge amounts of money on polishes because they look minging within a few days use anyway. |
#25 | |
Its my personal choice, each to their own. I dont do that with my DRZ, i just jet wash all the dirt off when i get back from green laning. |
#26 |
My bike gets used a lot now, so about once a week it gets the dead flies washed off and a general clean up. I cleaned my rear wheel the other day using Muc Off and was not very impressed. I used Hope ****-Sh1fter (Yes it really is called that) before and it was excellent, but Muc Off seems to be quite watered down.
Scrubbing my chain and sprockets made my arm ache, but the finish at the end was worth it and relubing a clean chain is so much nicer. Is paraffin easier to use than chain cleaner and does it require special disposal when finished? |
#27 |
You can clean the wheels with paraffin. Paraffin/kerosene is a solvent m'dear, so it never gets finished. The dirt will sink to the bottom of the jamjarso you can use the same paraffin/kerosene again and again. I pour a small amount into a jamjar and then use anold toothbrush to clean the chain. It's a filthy job, but the result is worth the effort IMHO.
#28 |
You'd be better using WD40 or Mr Sheen on your rear wheel than muck off JF. Old fashioned methods tried and tested
![]() Although that SDoc is great. I don't clean the chain side of the rear wheel that often, so its usually absolutely minging, but the Sdoc gets built up stuff off easily. Doesn't do bad on your chain either. But is expensive, and thankfullly I don't buy it and always leave an empty bottle!!! If theres none of that, the old fashioned method is required.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 Last edited by dizzyblonde; 20-07-10 at 10:33 AM. |
Cleaning your bike | Briddo | Idle Banter | 15 | 17-11-08 01:13 AM |
2 questions: 1 about overfilling oil like a complete mug, and cleaning the insides of gloves | Paul the 6th | Bikes - Talk & Issues | 26 | 31-05-08 05:32 PM |
Cleaning Questions??? | Drew Carey | Bikes - Talk & Issues | 43 | 13-04-08 03:50 PM |
Bike Cleaning | Duck-man | Bikes - Talk & Issues | 15 | 10-07-07 06:50 PM |
cleaning my bike | Dave The Rave | Bikes - Talk & Issues | 23 | 27-12-06 04:28 PM |
