#21 |
Ah, another option into the mix, *THAT'S* what I'm after, thanks
![]() Post 17 doesn't load for me on that thread, but... nice! For the flip side of the coin see here: http://www.nirvana-motorcycles.com/wordpress/?p=100 From carrying 11.4kg on a 7.5kg capable SW Motech alu-rack ![]() |
#22 | |
#23 |
Seems to me that that rack has too many pieces joined together at odd angles, i have just fitted a triumph rack which is one piece and bolts on in two separate places, 4 bolts under the seat as in that picture and two into the rear grab handle, seems very secure, will find out in two and a bit weeks
#24 |
MR UK1 - If I had the money to buy new kit I'd have the money to buy the expensive pannier system :-p
Bluefishman - I can't alter the design of it ![]() |
#25 |
no but you don't have to buy it.
#26 |
No, but I do need to buy something!
#27 |
Although I'm very unlikely to buy that one as it has a lower weight limit than the Givi system. Here's the fitting diagram for the Givi option: http://www.givi.co.uk/attachfile/con....man_sr121.pdf
#28 | |
Well that appears to be a lot better, although i guess if that design were to fail it would be along the tubular arm, you pays your money and takes your chances. |
#29 |
Don't forget though that link with the broken rack wasn't for a Gladius. Here's the mounting instructions for the Gladius version: http://shop.sw-motech.com/cosmoshop/...31_10000_b.pdf Although you could have looked that up yourself if you wanted to
![]() This is a bit beside the point, it's new options I'm interested in rather than ones I've already found and considered! |
#30 | |
Re the actual question, maybe it's best to decide what you are or are not prepared to compromise on and what sort of system you want and then decide whether you get Givi, Kappa etc as they are all going to have similar limitations etc. Last edited by MR UKI (1); 21-07-10 at 07:19 PM. |
rear brake pads Gladius | gfb | Bikes - Talk & Issues | 4 | 05-03-10 01:15 PM |
WTB rear luggage rack for a curvy | mikereno1 | Stuff Wanted | 1 | 21-06-08 03:54 PM |
Rear foot peg & luggage | Frogman | Stuff Wanted | 0 | 05-02-08 10:51 PM |
Rear end luggage question. | Ceri JC | SV Talk, Tuning & Tweaking | 16 | 31-05-07 01:13 PM |
Motorcycle & bicycle luggage systems | tricky | Idle Banter | 2 | 26-10-06 08:32 AM |
