Old 21-07-10, 05:05 PM   #21
Default Re: Increasing BHP of Pointy SV?
Originally Posted by cb1000rsteve View Post
It runs fine its just on off throttle fueling is a dog. The honda pulls smooth from closed to open in every gear. They do know how to fuel a bike them boys
You would not say that comparing first of injected SRAD to first injected blade. Or comparing an SP1 to errr... a GS750 with loose spark plugs, an air leak and a dead ferret in the petrol tank.
Set your TPS. If your bike is set up properly it will be smooth.
Old 21-07-10, 05:23 PM   #22
cb1000rsteve
TPS???
Old 21-07-10, 05:27 PM   #23
http://forums.sv650.org/showthread.php?t=55459
Old 21-07-10, 05:31 PM   #24
cb1000rsteve
thought it was Throttle postion sensor but i didn't have a clue i could adjust it!!! That how 2 thingy basically describes how my bike is on and off the throttle. cheers
Old 21-07-10, 05:32 PM   #25
So rather than h*nda being particularly good, it's just your bike that isn't running properly
Old 21-07-10, 05:35 PM   #26
cb1000rsteve
It should be set up properly in the first place really!!! Stupid corner cutting cheapskates!!
The Honda is sublime though. It will pull 30mph in top with a passenger on. smooth oove
But i shouldn't really compare it to the little oh SV.
Old 21-07-10, 06:12 PM   #27
mjc
h*nda/suzuki slanging match aside...
to the OP- spend your £500 on changing your final drive ratio, either by dropping a tooth on the front sprocket or going up a few on the rear. take the £490 change and spend it on beer and petrol.
changing gearing will improve acceleration at the expense of top speed. how often do you do 130mph? this will make a more noticable difference to than a couple more bhp.
Old 22-07-10, 09:10 AM   #28
Spend it all on suspension.
You will be so much faster on a well sorted chassis with a stock engine than on a stock chassis with a mildly tweaked engine.
Old 22-07-10, 10:06 AM   #29
Jayneflakes
Jayneflakes's Avatar
You know what is involved in doing that?
Listen, I am just a sweet little girly (snigger ) of course I don't know what is involved, but how hard can it be?
Actually, give me a few more months for my Restriction to end and we can find out. I have plans for my bike you see, I want to make it run on Bio Diesel and fairy farts!
How easy is it to run two engines together? Could remove the rear seat and bolt it on there easily enough!
In all seriousness, how much work is required to fit the 1000 in the 650 frame? Are the frame dimensions the same? I imagine that several up graded parts will be required to allow for the extra forces involved.
Jayne you're a Pussy Magnet
Old 22-07-10, 10:50 AM   #30
Lots of work. Custom exhaust, adapter plates, all new EFI system.
Used values increasing? Aidan SV Talk, Tuning & Tweaking 26 25-03-10 09:37 AM
2 more problems to the ever increasing list dmracing SV Talk, Tuning & Tweaking 5 02-07-09 06:34 PM
Increasing length of kickstand. pilot SV Talk, Tuning & Tweaking 3 05-08-08 12:49 AM
Increasing ride height Owen564 SV Talk, Tuning & Tweaking 8 01-05-08 07:59 PM
Increasing the bhp sprocket SV Talk, Tuning & Tweaking 7 14-05-05 03:55 PM
