#21 |
Just found the number for the nut and bolt i need to fit it and ordered them from wemoto. for anyone who need them its Bolt: 92153-0663 and Nut: 92210-1139 thanks to Mr Speirs who posted it in another thread.
#22 |
No worries.
You want a GSXR shock rather than a Kwak shock then. Pointys have a significantly softer shock to the curvy.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
#23 |
And a different length.
#24 |
got a gsxr shock, for a pointy i need a 10kg/mm spring the zx10 has that (im 16.5 stone) its also longer than the shock i have now and loner than stock by 8mm giving a 16mm rise over stock (1:2 linkage ratio)
#25 |
Cheers Mr spiers need tht info too.
Another Q: how hard was the swap to do?
#26 |
Its a bit daunting but not very difficult. The swap is easy its just modifying it to fit that's difficult. What I did, everyone has differing ways of doing it though.
You need to get gain some slack on the + and - cables which attach to the battery. Remove the tank hinge which also holds the battery in place. There is a section that rest against the battery, you need to hacksaw that part off and you can bend the remaining parts up and out the way flush to the tank hinge. You will need to cut a playing card size hole in the battery box so the resivour of the shock doesn't foul. Once you have the shock roughly in place you can see where to cut. Remove the fuse box and relays from the tray. You will not need the tray the fuse box and relay need to remain loose. What remains of the battery box needs to then be built up with foam (or something else suitable) far enough to just clear the resivour too far and you will have clearance with the battery issues. The battery will then tip 90 degrees, its tight but the battery will wedge down in the sub-frame and be supported by the foam. And that's it. Install the shock and reassemble. Oh and when installing the bottom shock bolt it will need to be inserted from the opposite side the standard shock bolt. This is because the dog bones are closer on one side than the other. I think ive remembered everything. I've done two this way now...getting quite quick at it ![]()
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. Last edited by Mr Speirs; 29-07-10 at 07:06 PM. |
#27 |
so quite a bit butchering under the seat
still going to get the shock nd do a mock up/ trial run to see what has to be done
#28 |
or you could stick the battery under the pilion seat but thats even more fabrication
#29 | |
Am v dubious about tipping a lead acid battery on it side
#30 |
They are sealed, its absolutely not an issue. My ducati has it's battery fitted on its side as standard.
Rear shock | Icanopit | SV Talk, Tuning & Tweaking | 17 | 29-12-09 09:15 PM |
636 rear shock | drag | Stuff Wanted | 0 | 31-07-09 10:18 AM |
Poor rear brake, suggestions? | Smoggy | SV Talk, Tuning & Tweaking | 14 | 26-02-09 07:09 AM |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
new rear shock | mc_phers0n | SV Talk, Tuning & Tweaking | 0 | 10-05-07 04:00 PM |
