Old 19-08-10, 01:44 PM   #21
mister c
mister c's Avatar
Default Re: Help please! my POS curvy won't start!
You can also use ones off Gixxers & also have heard that CBR600 ones fit.
You can get them off Ebay for not too much money, mine cost me about £30 if I remember.
On my old Curvy I fitted a Gixxer600 one & that cost me a tenner off ebay
Old 19-08-10, 05:08 PM   #22
Default Re: Help please - curvy won't start.
Find out what's wrong before replacing bits of bike.
Just a thought.
Old 19-08-10, 07:27 PM   #23
Roberrrrt
Just a thought.
Great bit of advice.
Got home this evening, tried to turn it on, fired up first time no problem?!
Decided not to start messing with the electrics since it was chucking it down - and I don't have a garage, so will see whether it's taxi to work time again
tomorrow morning or not.
Old 19-08-10, 07:47 PM   #24
Biker Biggles
Biker Biggles's Avatar
Was that after you charged the battery?Id still get the meter on it and check it all out,and Id check all the battery connections for tightness and good contact.Also the earths and feeds through starter relay to starter motor.The bike is getting on a bit and needs tlc from time to time.
Old 19-08-10, 07:51 PM   #25
Dave20046
Dave20046's Avatar
Take it back to the nobber that sold it you - or has he flee'd the country?
As said it's worth getting a cheap multimeter and testing a few bits.
Old 19-08-10, 08:59 PM   #26
feel the Reg Rec, if its getting pretty hot then I would also say that was the problem.
Regulator gets hot in normal operation - that's why it's finned - not a reliable manner of checking operation.
Originally Posted by hongman View Post
Not sure I'd want another Sv one as they are so notorious for being ****e...
Are they? What percentage of SV reg/recs would you estimate have failed?
Old 20-08-10, 01:47 AM   #27
Jamesy D
This hasn't been mentioned previously, so I might be totally wrong but it does sound a little like what I had a month or two ago, if so it might be worth your while just checking the ignition fuse. Mine did something similar and it took me an RAC callout and two days of stress to find out it was just a blown fuse.
Can't hurt to check in any case.
Old 20-08-10, 07:59 AM   #28
Roberrrrt
Thanks for all your suggestions guys, I'll be having a good look over the bike this weekend (with someone a bit more knowledgeable all being well) so fingers crossed it's an easy (and cheap) fix!!
Oh, and yeah I know Numbers, quite convenient that he's not in the UK right now
Old 20-08-10, 11:00 AM   #29
embee
embee's Avatar
Sound advice above about checking what's actually wrong first.
Whatever you find, a high percentage of electrical problems are to do with poor connections, and that includes fuses.
Go round as many connectors as you can get to and take them apart (there's usually a catch arrangement which has to be pushed in to get them apart).
Get some electrical contact cleaner (Maplins etc) or at a push use WD40/ACF50 etc. Spray and push them together a few times to ensure a clean contact.
Fuses are especially prone to corroding unless some sort of protection is applied, dielectric grease is perfect (you should already have this for the front plug cap anyway ) but vaseline is a decent substitute. Don't forget the main fuse in the green box behind the right triangle.
Please help - '99 curvy will not start maultin SV Talk, Tuning & Tweaking 14 25-10-08 05:08 PM
Curvy engine won't start, electrical buzz. Geoffrey Bikes - Talk & Issues 13 25-08-08 04:45 PM
My SV650S Curvy won't start. Ash_sv650 SV Talk, Tuning & Tweaking 24 27-06-08 04:51 PM
remote start on curvy aarond SV Talk, Tuning & Tweaking 3 24-05-07 06:32 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
