Old 02-11-10, 02:24 PM   #21
danf1234
Default Re: Infamous stalling problems have returned
I don't know TBH, I didn't have them fitted to my K6.
Old 02-11-10, 02:47 PM   #22
embee
embee's Avatar
Originally Posted by danf1234 View Post
...Appartently the engine relies on a signal from this lever to tell when the clutch is pulled in, especially at low revs.
Only a guess but if the ECU has an overrun fuel cut-off function it may use a clutch signal to ensure reinstatement whenever the clutch is pulled in (combined with a neutral signal/rpm/wheel speed etc). If this is the case it could catch it out if the revs dropped lower than it expects without seeing the clutch signal . That kind of thing anyway.
With cars there's also quite often different idle speed functions depending on things like electrical load, aircon, and also if the car is moving above a certain threshold speed, probably not relevant to a bike but just for info.
Old 02-11-10, 02:52 PM   #23
danf1234
That sounds very similar to what Suzuki tried to explain to me.
Old 03-11-10, 08:57 AM   #24
maxinc
ECU's are funny business. I had once my car over revving because of a faulty water temperature sensor. Funny thing was, after the sensor was replaced, it took the ECU some 20-30 miles to adjusts itself, as the mechanic predicted. Glad you sorted it ... and glad I didn't bid on your levers :P
The Infamous Suzuki Build Quality!! captainsmelly Idle Banter 9 17-02-09 11:48 PM
The Infamous Stratford Swans cb5_keith Photos 2 11-06-08 08:04 PM
stalling problems steveg SV Talk, Tuning & Tweaking 2 06-11-06 06:44 PM
Its returned home... Alpinestarhero SV Talk, Tuning & Tweaking 4 19-10-06 10:44 AM
I've returned (At last) (Nearly) MattTheLoony SV Ecosse 12 12-06-06 09:59 AM
