Old 20-10-10, 08:55 PM   #21
speedplay
Default Re: House - update
Trench blocks are good for a good base, use them on the inner skin, face bricks on the outside.
Better on costings too
Old 20-10-10, 08:56 PM   #22
Money is no object for Col
Old 20-10-10, 08:58 PM   #23
speedplay
Bloody jocks....
Old 20-10-10, 09:00 PM   #24
-Ralph-
So, ignore my last post then
On bigger walls id suggest a weeper with weep holes in the joints every now and then, if you can control the water, the ground wont move as much
I used plastic tube every two blocks along the bottom course of the wall as weep holes. You can see a couple of them in this pic either side of the step
When it rained heavy, or when the turf was just laid and I'd had the sprinkler on they didn't so much weep as pour!
Then they poured into the gravel between the wall and patio, seen in the next pic,
which is hiding the sections of perforated field drain I was telling you about on the phone. These terminate below the bottom step, into a t'piece that connects to a drain pipe running under the patio and into the rodding point that you see by the tracks of the mini digger. The guttering downpipes off the garage roof also pour into gravel and field drain connected into the same place. This is the bit I kept covered from the buildings inspector!!!
Old 20-10-10, 09:03 PM   #25
-Ralph-
btw im not picking at your work
Don't worry about that, I know I'm not a pro! Lots of head scratching, talking to my aunts and uncles (ex-builders), and inventing my own unproved solutions went on during that project
Old 20-10-10, 09:05 PM   #26
Someone read up or got good advice Col, im impressed
Old 20-10-10, 09:05 PM   #27
-Ralph-
I had no idea what to use. I walked into the building section of B&Q Warehouse, looked at the materials available, scratched my head, then filled the boot of the car with engineering brick because it was cheap!
EDIT: In fact I have no idea what a trench block is - what is a trench block?
Old 20-10-10, 09:12 PM   #28
-Ralph-
Do you think the pillars will hold it, or should I really have gone to the effort of double skin? Not that it matters once this house is sold, just in case I ever decide to do it again.
Old 20-10-10, 09:14 PM   #29
-Ralph-
Ignore this, I've just realised what it is, they were used in the founds of the house below the stone work.
Old 20-10-10, 09:23 PM   #30
Personally, if you are holding back earth of any size then i would do a double skin.
Trench blocks are basically interlocking blocks btw, you use these as a base, put ties into them then when you build your wall it will bond to them really well.
If you want a super strong wall you could use the trench blocks as your inner skin, cos they interlock and they are mortared together, they leave a really strong structure.
Hollow blocks are good as well cos you can back fill these with a lean mix of concrete.
Would you buy a house with this? suzsv650 Idle Banter 32 04-06-10 10:13 AM
My house and what to do with it Gazza77 Idle Banter 13 16-05-08 12:45 PM
Flooded house update darylB Idle Banter 6 30-07-07 10:02 AM
In the dog-house..... Jabba Idle Banter 18 09-04-07 11:02 AM
Is there a Dr Bob in the house ? Shooter Bikes - Talk & Issues 2 02-04-05 12:02 PM
