Old 22-12-10, 10:47 PM   #21
Stonesie
Default Re: Bar end weight removal?
Thread the bolt back into the remains CAREFULLY!! and only a few turns, if you push the nut out of the far side of the rubber block then it will be a total mare to get it out.
Then spray some WD-40 down the bar, brake cleaner will do too as it will stay liquid for long enough to wiggle the rubber block out then evaporate so the new bar end will grip.
Edit, our garage is pretty cold too, lost a can of cola that was just behind the door (it split wide open)....
Old 24-12-10, 12:33 AM   #22
5hort5
Strangely did mine last weekend whilst fitting some oxford heated grips, drilled one off with a 12 mm bit and it was fine, the bolt end came off and the bar end slide over the bolt shaft and then I undid the bolt with mole grips. The other one as Quest said was tight on and it came off just by turning the weight. in water pump pliers and a rag.
5hort5 is offline   Reply With Quote
Anyone else here trying to put on weight? rubberduckofdeath Idle Banter 143 30-10-07 05:19 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
What weight oil do you use? andyb SV Talk, Tuning & Tweaking 23 24-06-07 02:27 PM
Bar end weight Diveboy Stuff Wanted 4 07-02-06 02:48 PM
Weight mpaton2004 SV Talk, Tuning & Tweaking 30 18-01-05 10:15 AM
