Old 23-01-11, 07:13 PM   #21
Default Re: Gsxr rear shock bolt - where from?
cool, dont worry most people on hear (specially me) have asked stupid questions
+1 same here!
What shock you ended up with?
Old 23-01-11, 11:39 PM   #22
g13unisol
I went for a gsrx1000 k5/6. Do I need to do anything with it before I fit.
Old 02-02-11, 10:59 PM   #23
g13unisol
Fitted rear shock today thanks for advise was easy in the end little bit of cutting of battery tray. Replaced battery with small one and ally tray works great.
Old 03-02-11, 09:27 AM   #24
Nick_69
Nick_69's Avatar
You rele notice the difference on the first ride
Was SV650S K9
Now GSXR 600 K9
Old 03-02-11, 05:13 PM   #25
g13unisol
You are Not wrong the only problem is it shows up how bad the front is. My mate had a go and said it was like the bike had a hinge in the middle. So need to sort out front hyper pro I think
Old 03-02-11, 08:06 PM   #26
barwel1992
if ure doing the front ether go with emulators and springs or go with a full front end swap, i have had just springs and thought they were ok until i got the front end i have now .... and you just cant compare the two
Is there a rear shock u can bolt on with out too many mods for a K1 K2 650S Sv-Rat SV Talk, Tuning & Tweaking 16 24-06-10 09:04 PM
rear shock bolt GSXR pencil shavings SV Talk, Tuning & Tweaking 4 25-04-09 04:26 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
nuts & bolt for GSXR shock chris SVK3 SV Talk, Tuning & Tweaking 1 12-01-05 10:51 PM
