#21 | ||
I used to drive most of my way to work in 6th gear with just a tiny bit of throttle and the fuel computer reading anything above a couple of hundred MPG. I lived at about 1000 feet and worked 15 miles of straight motorway away at about 300 ft. Thing is I couldn't get more than 35 or 40mpg on the way home when I had to climb the same hill, so overall 50-60mpg was my best average. I could get just the same with the cruise control set to 75mph on a 350 mile journey from Scotland to Birmingham, which is up and down over Dumfries and Galloway and the Lake District, with every motorway gradient in between, so I don't think it really makes much difference. It all averages out.
Wouldn't you coast further in neutral than with the clutch down? The wheels are not having to spin the driven side of the gearbox and the clutch plate. Quote:
When you hit the 1/2 mile sign exiting a motorway, move over to lane 1 gradually loosing speed with your foot light on the throttle, when you see the 300 yd sign, foot off the throttle completely, and let the car slow down naturally. You'll be down to 50 mph or so by the time you hit the slip road and usually down to 15-20mph by the end of the slip don't touch the brakes unless you have to stop at the end. With the likes of roundabouts and junctions, throttle off as soon as you see it, earlier if it's downhill, and let your car slow gradually, just the same as above. If you can watch the traffic and anticipate ahead as you approach the roundabout or junction, you can try and time it so that you don't have to brake at all, you arrive just as there is a gap in the traffic flow, and you accelerate gently away again. Your average MPG is also directly related to how far down your foot is on the accelerator pedal, go for a 'light touch' approach with your foot, only using just as much throttle as you need, and you'll use less fuel. Another trick with an auto box is if your feel it's holding a gear for too long when accelerating, lift your foot slightly as though you were up to the desired speed, and it'll change up a gear, then reapply throttle gently to get back up to the speed you really wanted, but not hard enough to make the box kick down again. It'll all drive the people behind you nuts, but who cares if you are saving money. Last edited by -Ralph-; 26-01-11 at 08:34 AM. |
#22 | |
Why do they do that, and what traffic ( apart from bluepete chasing scrotes ) comes from the left on a roundabout?
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#23 | |
though i'd find you infuriating on a motorway if you done that - that's why its called a de-acceleration lane! ![]() |
#24 | |
#25 |
Its right, when coasting in gear, the engine is still being turned over, it doesn't need fuel so no fuel is injected. The driveshafts spinning keep the engine going.
Take it out of gear, no natural spinning, hence fuel is needed to be put in to keep it turned over. As for Priuses, no, no clutch, boss has one and I drive it often. Front heavy awful handling car. No all that great on fuel either as its no more economical than any other 1.6 engine, and at motorway speeds it only does 40mpg odd. Where it excels is slow speed, town running. But the motor is terrible and to pull away just using electric is stupid. I'd say just using the motor, so free running, is 0-40mph in about 20 seconds. so you have to use the engine as well, knocking the economy down. He gets about 45mpg average, which is what a normal derv runs at. I've had it over 100mpg though pottering around. Dash/dials are good, but materials are terrible (recycled). Technology on the braking kinetic power return is a good idea, but needs to be made more mainstream and available on other more powerful cars, with bigger/better brakes to return more charge to the motor. |
#26 |
#27 | |
Just before he pulled away when the lights changed, the brakelights flashed again. He was putting it in Park every time he stopped! |
#28 |
He's on about the idiots who can't plan ahead who get in the way when you are trying to drive smoothly
#29 |
#30 | |
Yorkie Chris has explained it. Why oh why do people stop at a roundabout when there's nowt coming?
Electra Glide In Blue - Now showing | maviczap | Idle Banter | 0 | 01-10-10 08:11 PM |
Pulse Jet Push bike | Scoobs | Idle Banter | 5 | 06-08-08 04:07 PM |
Pulse Jet | Bluepete | Idle Banter | 12 | 09-02-08 04:27 PM |
Pulse generator coil | yorkie_chris | Stuff Wanted | 11 | 15-09-07 04:28 PM |
Pulse Generator Coil | POGS69 | Stuff Wanted | 7 | 14-08-07 09:42 AM |
