#21 |
Rides fine, going to go over it and give a clean this weekend
#22 |
Checked the front tyre it looks as though it has been changed for the 120/70 higher profile, question is if i raise the forks up to where they should be will it make a huge difference from a 'standard' tyre.
Also what is the difference between 120/60 and 120/70 i mean physical dimentions? Cheers Guys |
#23 |
hmm considering theback is lower than stock and the tyre is bigger than stock your turn is speed will be slow as hell with the forks where there supposed to be basically the bike will look sort of like a chopper high at front low at back
#24 |
/70 is steeper profile which will cancel that effect out somewhat.
Bring the forks down in yokes until it is safe (you can remove top caps and let forks drop down to check where full travel position is), if you feel it needs to turn faster. TBH I'd just put the forks to stock position though.
#25 |
Now when i am on it it feels high at the back and low at the front, to look at it looks high back end wise aswell. I don't think the shock is off a GSXR tbh, how long is the stock one i will go measure it and see the diffenence
#26 |
Will put the forks back down i think, shock is currently 13inches (ish) long, that's with the bike on its stand, that seems quite long to me.
#27 |
Stock is 337mm, from top of my head K4 shock is 332.5. Ideally you want a shock that's 350mm+ but you won't find one on a stock bike.
#28 |
So how have i manged to get one thats 290mm? it does look adjustable but this seems like a mssive adjustment to make. I know its not stock.
Unless of coarse i measured it wrong i did it with a ruler at work. If i urn the adjuster this won't make the shock longer will it? |
#29 |
It won't make it longer but you have measured with some of the bikes weight upon it which will compress it a bit, especially being so soft.
Post a couple of pics lets see if we can identify it.
#30 |
If its been messed with it may well have non standard length dog bones which alter rear ride height.
SV650S Lowered | Natsie 83 | SV Talk, Tuning & Tweaking | 6 | 30-07-09 09:31 PM |
Lowered Seat for Sv650s K1 | Milky Bar Kid | Stuff Wanted | 9 | 20-04-09 03:14 PM |
Lowered front seat for an sv650s K3 | kirsteenshort | Stuff Wanted | 1 | 13-07-08 10:12 PM |
lowered sv650s | skeetly | SV Talk, Tuning & Tweaking | 7 | 16-03-08 06:56 PM |
Lowered seat for SV650S - curvy | delpel | Stuff Wanted | 3 | 26-06-07 03:50 PM |
