Old 07-05-11, 07:13 PM   #21
Rob969
Default Re: R6 throttle tube, is this the part number?
Think i might have to give this a go as well next month when i have time, I had the same issue when taking my barends off to give them a paint as mav said drill them out then a pair of mole grips did the job for me
Old 07-05-11, 07:17 PM   #22
leebex
but, can any of you help with this query?
http://forums.sv650.org/showthread.php?t=166125
Old 07-05-11, 07:18 PM   #23
Just replied
Old 07-05-11, 07:19 PM   #24
Rob969
sorry mate i took mine to my local diy place and said can i have something the same size as this. The only thing he had was slightly too long so i chopped a bit of and fitted it.
Old 07-05-11, 07:35 PM   #25
leebex
Just replied
Old 07-05-11, 08:09 PM   #26
NedSVS
A good tip to remove bar end screw (curvy model) is to wrap a protector around the bar end (I use a thick piece of leather - old belt) and use a pair of mole grips or gland pliers at the same time as screwdriver, turning both in the anticlockwise direction.
Old 07-05-11, 08:13 PM   #27
Didn't work for me and ended up drilling the head off, would have saved a lot of time if I'd done this straight away
Old 07-05-11, 08:17 PM   #28
leebex
might be worth a go before the screw head is too mullered, if it isnt already
Thanks for the tip
Old 08-05-11, 08:06 AM   #29
NTECUK
NTECUK's Avatar
i got some new bar ends ,ready to do the mod .but the mini flip front is net on my list.
Old 08-05-11, 08:40 AM   #30
payner123
So looking at the canyon chaser site is it not worth doing to a 650 s pointy? I am concerned as have done it to mine a few months ago and all seems to be ok...but a little bit dubious now!!!
Throttle Tube (K3) Hoody90 Stuff Wanted 13 16-03-11 06:44 PM
The R6/R1 throttle tube on SV - what does it do? danf1234 SV Talk, Tuning & Tweaking 4 24-05-10 07:55 AM
Need a new throttle tube TightRS SV Talk, Tuning & Tweaking 2 23-12-08 10:13 AM
R6 throttle tube Quiff Wichard SV Talk, Tuning & Tweaking 34 04-06-06 08:42 AM
R6 throttle tube for a K4 SVeeedy Gonzales SV Talk, Tuning & Tweaking 0 04-01-06 12:22 PM
