Old 10-04-11, 06:02 PM   #21
Curvieone
Default Re: Bike feels twitchy around corners, is my rear squaring off?
Rear wheel bearings ok? just asking, a GIXER750 I had did that, the bearings were shot.
Old 12-04-11, 10:21 PM   #22
Maverick9999
Thanks for the advice guys. I didn't realise tyre pressures fluctuated so much, I must only have checked it twice in the 18 months that I've had it :$. Bike is an 04 plate with about 18k on the odo. It had a major service last May. Will be more vigilant next time! Having them back to standard pressure does feel a lot more 'stiff' at the rear now. Will take it to a garage soon to check if anything else is suspect... problem with these things is garages tend to find faults as a response to driver's paranoia, where's spannerman when you need him!
As for the shocks/suspension, I can't really tell until I take it to a garage. Anything I can do to check it myself?
As for bearing play, I've checked and there's not much movement on either wheel...
Old 13-04-11, 05:48 AM   #23
Where are you based? There is YC up north if you can't get to spannerman.
Old 13-04-11, 05:58 AM   #24
Nobbylad
Nobbylad's Avatar
You should check your tyre pressures regularly along with the overall condition of the tyres looking for foreign object damage. Obviously depends on how often you ride, I check the tyres visibly daily and check the pressures once a week because I use the bike to commute.
Old 13-04-11, 02:28 PM   #25
big jc
ive just had the same problem, one of my mate sugested tyre pressure may be the cause and low and behold a bit of air and the bike feels good as new!
This weekend I've been mostly squaring off my rear tyre! walkaboutandy Thames Valley 7 27-07-10 06:20 PM
curvy feels twitchy ocr_sv SV Talk, Tuning & Tweaking 13 23-09-08 07:04 PM
My bike feels funny melody Bikes - Talk & Issues 10 27-10-07 11:28 PM
Twitchy corners remf179 SV Talk, Tuning & Tweaking 20 23-05-07 10:16 PM
rear tyre squaring off? hcorf SV Talk, Tuning & Tweaking 18 25-07-06 06:57 AM
