Old 30-05-11, 05:19 AM   #21
Gazzaleachie
Default Re: hydrolocked engine grrrrrrrrrrrrrrr
Sorry i only posted from past experiance i have and still have said con rod from engine which had oil in the cylinder and the starter bent that like it was made of cheese! But your right without having the bike in the flesh how can you diagnose the fault?
Cheers. Gaz
Old 30-05-11, 08:28 AM   #22
ImplodedHamster
just curious, would the starter motor even have enough power to bend it?
Old 30-05-11, 08:42 AM   #23
We get some right bolox posted on these threads sometimes. How the f**k you can diagnose with certainty a bent con rod, 'cos a starter motor tried and failed to turn over a hydrolocked engine, completely f**~**g beats me!
Sorry Ralph but I don't remember reading that anyone had said with any certainty that the conrod had bet, most of said MAY have.
We were just going on the infomation provided by the OP and the title of the thread!
It is possible to bend a conrod buy turning the engine over if one cylinder is hydrolocked, Honda CBX1000 were prone to bending rods if the fuel tap was left in the on position, as it filled one or 2 cylinders with fuel. Staring the engine would result in bent conrods, as YC and myself correctly pointed out you cannot compress a liquid.
Honda cured this in later models by fitting an electric fuel tap.
Its difficult to diagnose from a distance, but its not all bollox.
Old 30-05-11, 08:59 AM   #24
-Ralph-
Queue Roy Walker "You said 'might have', Andrew said..."
I'm with mavi, sounds terminal.
The OP then concluded
Originally Posted by farquare View Post
i've pretty much resigned myself to the worst by now, looks like no biking for me this year.
thanks for the replies and suggestions.
Nobody offered any other possibility. I'm not surprised the OP feared the worst, the thread reads like a conclusion to me too
Honda CBX1000
The CBX1000 was in inline six. It's most likely to have bent a con rod when the the hydrolocked cylinder was not the first in the firing order when the engine started, so the torque required to bend the con rod is most likely to have came from other cylinders firing before it, not from the starter motor. This is a twin and the OP has told us that the engine never fired, but stopped the starter motor immediately on him hitting the button. What's more the con rod connected to a 165cc cylinder in a 1000cc six, is probably going to be a lot lighter than the con rods in a 325cc per pot SV.
Old 30-05-11, 09:06 AM   #25
Compression test will tell for sure.
I am sticking with initial thought of oil in carb being problem.
Old 30-05-11, 09:17 AM   #26
farquare
Couldnt get a comp tester this morning, will try to clean the carbs this morning and see if that makes any difference then venturee out later to try and get a comp tester.
Any particular bits of the carb i'd need to pay attention to?
Thanks for all the suggestions folks.
Sent from my U20i using Tapatalk
farquare is offline   Reply With Quote
Old 30-05-11, 09:20 AM   #27
Pilot jet and air jets.
You got compressor? Just blow through holes, no need to take off bike just be careful because you might end up wearing some petrol
Old 30-05-11, 09:26 AM   #28
husky03
let me know if you want to borrow a set of carbs to switch over bud and you can come over and get them
h.
Old 30-05-11, 09:34 AM   #29
farquare
cheers husky - appreciated, I'll get a comp tester first and see what the readings are like.
just had a quick look on the net, most of the comp testers come with a few thread adaptors, what size is a sv plug hole?
unfortunately i dont have a compressor, i'll just get under the tank and see what i can get to....
Old 30-05-11, 09:39 AM   #30
husky03
i've a wee pancake comp you can borrow also mate
Engine oil change - 5 months no engine starting sv650sfan SV Talk, Tuning & Tweaking 2 04-03-11 08:10 AM
Engine cleaning b4 engine strip w.i.p muzikill Photos 2 16-01-11 06:20 PM
engine bolts for point engine pookie Stuff Wanted 6 01-10-10 01:50 PM
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
