Old 30-05-11, 02:22 PM   #21
Default Re: Angel eye HID install
Wont you have a narrower field of view with them vertical, ie not as wide a fan of light?
No way, these things are ridiculously bright. I could just have one and it would still be 20 times brighter than the dominators. And the beam pattern is perfect
think you missed the point Darren. If you have two on top of each other, they may burn the curtains of granny down the road with their epic brightness, but if they only light up a bicycles width, they're a bit ****.
On the other hand if they are side by side, you'll burn her whole window through....
You could have four like Peg, not only burn one set of curtains, but four. Bright as hell, four in a row, six with all of them on, lights up two carriageways, thats the one your on, and the one in the opposite direction. On a motorway.
So with that in mind. I go the right way up, horizontal
Old 30-05-11, 02:56 PM   #22
Well think about what causes beam patterns to go way they do. That 4" difference will make no difference, it is direction light comes out of lamp that is going to make difference.
Old 30-05-11, 05:34 PM   #23
Huwbee
VERTICAL
Old 30-05-11, 09:34 PM   #24
Na I knew what he meant. I tried out one single HID when I got them and its beam pattern and overall spread completely drowned out the two little yellow dots from the dominators. The spread from the projector lens is really wide. Having them side by side wont make any noticeable difference
I might get some pics to show the difference between them
Old 31-05-11, 08:40 AM   #25
Triton
horizontal - but right up under the clocks
Old 31-05-11, 08:52 AM   #26
Viney
Side y side makes your bike look like the robot from short circuit
Old 31-05-11, 09:19 AM   #27
Reeder
Vertical.
Old 31-05-11, 01:09 PM   #28
daveyrach
'Number Jonny 5' in that Asian accent!
Old 31-05-11, 02:22 PM   #29
Roberrrrt
vertical
Old 31-05-11, 03:23 PM   #30
_Stretchie_
Large Member
_Stretchie_'s Avatar
Vertical
How to amuze an idiot:
Look right-> <-Look Left
Pirelli angel Baz Tyres 62 29-02-12 11:22 PM
Pubs around Angel wyrdness Soho Massive 2 14-12-10 08:40 PM
Pirelli Angel STs TheRamJam Tyres 4 27-07-10 11:59 AM
Pirelli Angel ST Italianjob Tyres 5 12-09-09 11:23 AM
Road Angel KrZ Bikes - Talk & Issues 10 20-10-04 12:54 PM
