#21 | ||||
That's why I sold the Vectra. It was over 80,000 miles, the cambelt is recommended at 100,000 or 6 years, I wasn't happy with that so got a quote and the garage told me they have known them to go early. Then it needed pads and discs, a coolant change, a brake fluid change, and it wasn't running at the correct voltage, so electrical gizmo's were playing up if lots of current was being drawn, so it needed either alternator or battery. My wife and son are going to France alone in August and the last thing they need is an electrical breakdown or a snapped cambelt, so I decided just to take the £1000 it needed, and put that towards a new car.
![]() I was quite pleased to learn at 60,000 miles the Ibiza (basically the same car as the Polo) also has a cam chain. Not sure about that Dizzy, you have a very expensive car to run. I spend much more on the Daytona than I do on my wife's Ibiza. Mainly tyres, the car has just had it's third set of tyres in 8 years, and they'll be on there for another 4 years. 4 tyres costs half what two tyres costs on the Daytona and last about 30,000 miles. Service cost is similar as they both get done annually, rather than based on mileage. The car doesn't need chain and sprockets and is better on fuel. Quote:
#22 |
Where is that old John Bull printing set----money to be made here
#23 |
The reason for doing the water pumps on the newer VW's is due to them having a plastic impeller on a steel shaft that seperates when it feels like it, some as low as 20k. My 04 passat tdi had full history with 52k when I bought it.. 4 months after the belt was done (50k) the pump packed in! Now have a MK5 golf, belts recommended at 40k or 4 years, take it they have had probs with the long service belts at some point.
(Will be doing the work myself, never had problems selling as long as all the service receipts are there) |
#24 | |
They have discovered a fault somewhere and are using a shorter service schedule to fix them rather than risk a recall. |
#25 | |
#26 |
so would the belt require doing on my astra estate soon, 55 plate with 35,000 miles?
#27 |
#28 |
You'll be shocked to know that my Alfa 156 has to have it's cambelt changed every 36,000 miles!! Now that's a ****ter.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
#29 | |
Stop and I will be with you. They were not where they said, another mile up the road on a car park and awful traffic to get there. Lifted the bonnet, thermostat had punched its way through the plastic housing. Now that is hot. Why did you not stop where I told you to? Because mum said I should stop here not on the road. Try telling a woman about the damage an overheating engine does and why not to run it. So tows it home, new thermostat and housing. and it just isn't cooling right and me thinking they have cooked it somewhere. It is as if the pump isnt working. Sod it pump off and the plastic impeller isnt on the shaft, fish it out. The shaft is knurled and that is supposed to hold the impellor. So off to the local discount Volkswagen shop who say it is a well known problem. So new water pump with brass impellor, and belt kit. One think I tend to do is write in white paint the mileage on the belt cover. That way should anyone ever look, It is obvious when it was done.
Not Grumpy, opinionated. |
#30 |
Paint or a sticker is the norm when a belt change is done also a little note on the service book.
Listening to all these woes perhaps I have been lucky but knowing about them being one reason I changed to chain driven cam engines.Admittedly they can have faults as well but they seem to be fewer in comparison. Considering the number of engines built it is inevitable that you will have a rogue one every now and then but it is always them that you hear about,not the ones that run trouble free for year in year out. If it is one in a thousand with problems perhaps the manufacturer bean counters consider this acceptable. Last edited by Dicky Ticker; 18-06-11 at 08:26 AM. |
I think I've only ever had a rant on here about twice but..... | Paul the 6th | Idle Banter | 44 | 06-05-10 11:50 PM |
I need to RANT | slark01 | Idle Banter | 1 | 20-02-10 07:09 PM |
Rant Rant Rant Bloody fair weather crotch riders | amarko5 | Pennine Massive | 55 | 04-06-09 05:32 PM |
council rant + gritting rant | timwilky | Idle Banter | 9 | 03-12-08 09:04 PM |
RANT! | Ward8124 | Idle Banter | 3 | 20-04-06 11:32 AM |
