Old 22-07-11, 03:43 PM   #21
Default Re: Brake Pads and Servicing Brakes?
might be worth a PM to one of the resident spanner monkeys to give your callipers an overhaul while you are away.
or since you are half way there 'popped piston' give them a service yourself.
Old 22-07-11, 10:09 PM   #22
hongman
Originally Posted by metalmonkey View Post
Where do I get them from? How much are they, how long does it take? I have very little free time.
Wemoto, check their website for calipers seal kit prices.
Time depends in the current state of said calipers, experience, tools for the job. If you are doing the seals you may as well clean and grease the important bits while you are there.
Not including the time it took me to split the calipers and manually clean them, took me a few hours to remove, strip, grease, reassemble and bleed the brakes.
Of course if you have problems getting pistons out and splitting the calipers this time can grow a lot, mostly dependant on what tools you have available (I had no breaker bar etc)
Old 22-07-11, 10:10 PM   #23
hongman
Oh and seized retainer pins can be a right pain...
Old 23-07-11, 09:34 AM   #24
metalmonkey
Is that what I need?
http://www.wemoto.com/bikes/Suzuki/S...l_Front_Brake/
Old 23-07-11, 04:03 PM   #25
hongman
Looks the ticket.
Old 23-07-11, 04:21 PM   #26
dont forget the RRG while you are at it. wemoto's price is not bad for RRG.
Old 23-07-11, 07:03 PM   #27
SV Mad
Strip the calipers and clean all the parts in new brake fluid. Have you got the service manual? The section for brakes is covered in the chassis section and will help greatly. If not PM me and i'll see if I can email a copy. Although its 11Mb and may not work.
Old 24-07-11, 10:57 AM   #28
No don't do that.
a) it's horrible sh*t and you'll end up wearing it
b) it crystallises if left behind the seals and actually CAUSES them to seize
c) brake cleaner works better to clean them
Old 24-07-11, 03:10 PM   #29
SV Mad
No don't do that.
So Suzuki and Haynes are wrong!! Just don't leave any behind the seals and it saves buying cleaner as well.
Old 24-07-11, 04:28 PM   #30
bigchris
I used brake fluid to clean mine as per Haynes manual, they were fine
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Front brakes, brake pads. metalmonkey SV Talk, Tuning & Tweaking 47 19-11-09 11:06 AM
Servicing my brakes and fitting braided lines Grinch SV Talk, Tuning & Tweaking 20 09-02-07 02:06 PM
Servicing brakes... valleyboy Bikes - Talk & Issues 11 25-04-06 07:34 AM
Servicing my Brembo's (Brakes) Cloggsy Bikes - Talk & Issues 6 04-04-06 09:50 AM
