#21 | |
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#22 | |
Besides which it'll be an oil munching frame shredder that cost half as much as his oil munching frame shredder and I'll have a fallback plan. |
#23 | |
Does your engine rev then pick up speed after? |
#24 |
Yeah, perfectly fine after a few minutes. I'd say it's only the first 3 or 4 times you try to get it over 2k when stone cold it struggles. Last for less than a minute really. After that it's fine. Not really a problem at the moment, just one to keep an eye on me thinks.
#25 | |
#27 | |||||
Where specifically? Quote:
Was the oily one about 3/4" in diameter? Quote:
1) Pistons/rings and cylinder bores never make a perfect seal, there will always be some blow-by that makes its way into the crankcase, in times past this was vented to atmosphere, but recently it's not been considered cool 'n groovy to chuck various hydrocarbons and fractions of incomplete combustion into the air, so it goes into the airbox where it's drawn into the motor and burnt. Also if the crankcases were unvented, blow-by would increase the pressure in the cases and oil leaks would be likely amongst other problems. 2) Crankcase pumping - when the piston goes downwards the space above it expands, unsurprisingly the space below it does the opposite. If you have a multicylinder engine where the pistons move opposingly, like an inline four - two at the top, two at the bottom, as each falls and reduces the volume of the crankcase, another rises and expands it, thus the overall volume of the crankcase is unchanged. With a V twin like an SV; common crankpin, 90ᴼ between the cylinders, when one piston is at the top of its travel the other is at midstroke, turn the engine one revolution and one piston is back at midstroke but the other is now at the bottom of its travel - thus the crankcase volume expands and contracts by the swept capacity of one cylinder every time the engine turns, in the case of an SV650 nominally 325cc. That's quite a sizeable pump, and when the engine is spinning at a reasonable rate, (6000rpm is 100 revs a second), inside the cases is far from calm and serene, and there's loads of oil mist being thrown around which that handy pump would want to chuck out of the way, hence my SV1000 having two big fat crankcase breathers and an oil separator to get that oil back into the motor, (the box into which the breathers go on the base of the airbox is baffled so oil won't pass through it*), instead of blown all over the scenery, whereas my ZX-6 has one weeny little breather pipe as there's much less crankcase pumping to bother it. *Yeah, right.
#28 |
#29 | |
I thought it relevant on an SV forum, whatever's being discussed, and as the above is written in reply to question as to the function of the breather, it seemed entirely worthwhile making it plain what and why what does what.
#30 |
Tbh your explanation went over my head after that line, I thought I'd point it out as I wasn't sure how much of your explanation was transferable between bikes
Tonights cake, brought to you by DizzyB ... | dizzyblonde | Idle Banter | 19 | 25-01-11 08:56 PM |
Today I have been mostly tinkering. | Baph | Bikes - Talk & Issues | 23 | 01-06-09 08:21 PM |
Tonights game...musical top trumps | dizzyblonde | Idle Banter | 63 | 05-11-08 11:34 PM |
Tonights dinner - important | Tara | Guildford Massive | 15 | 07-12-07 04:32 PM |
tonights crisp | timwilky | Idle Banter | 5 | 01-11-07 11:39 AM |
