#21 |
Junior Member
Did the plugs (the last one was a struggle) and a few more bits. Bike is running well.
Is this the correct battery time down strap?https://photos.app.goo.gl/fzbS9rVPgPzKTtYg9 Last edited by RS2K; 19-07-20 at 05:26 PM. |
#22 | |
When looking on SVRider.com ( USA ) found this link to Gladius service manual ( 584 pages ), 1st link is to SVRider thread and 2nd to manual location you can download PDF and save it on your PC - there may be some differences to USA model but probably 90% will be same in UK. https://www.svrider.com/threads/glad....134047/page-5 https://docs.google.com/uc?id=0B5u2i...xport=download
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 20-07-20 at 07:39 AM. |
#23 |
Junior Member
Hmmmm.
Here's the ebay listing:- https://www.ebay.ie/itm/Suzuki-SFV65...53.m1438.l2649 I'll check the battery size. Thanks again SV650rules. |
#24 |
Junior Member
The battery is a bit too tall. I can see this because fuel tank support rod lays down really tightly on top on the battery itself so there'd be no room for a battery cover.
I fitted some OEM brake and clutch levers - a bit improvement over the stubby things that were on the bike. https://photos.app.goo.gl/g1y7iEd9YeNFAaH59 p.s. Would anyone know the paint code for the frame? It's red. Last edited by RS2K; 24-07-20 at 04:35 PM. |
#25 |
assuming it's a 2015 Gladius, the frame colour is YVZ (pearl mira red)
https://www.fowlersparts.co.uk/parts...-gladius/frame (last 3 characters of part number of frame)
2016 SV650AL7 2023 GSX-8S |
#26 | |
Junior Member
It's earlier - a non abs 2010 model. Your link (thanks for it) suggests the paint is AR4 Red. |
#27 |
Junior Member
Mira red code YVZ.
#28 |
Junior Member
So I bought a 12A-BS battery (I hope that's the right size) and also that battery tie down strap thing off ebay. I'm pretty sure it'll fit.
I also ordered that Mira Red touch up paint. I've a bit of work to do in removing some surface rust and loose paint, treating the rust with Rust Remedy or similar, and then applying a bit of original red over that. When that's done I'll see what happens next - the wheels would look great powdercoated in original black, and the bar ends too maybe? |
#29 |
Junior Member
#30 |
I see you now have a place the clip the plug thingy that was floating around behind fuel tank before, good job.
newbie/racing a Gladius | dapsrsv4 | Racing and Paddock Chat | 14 | 07-04-15 09:49 PM |
Hi - newbie with Gladius | fazerjane | Idle Banter | 22 | 30-05-09 09:25 AM |
Newbie but oldie (sort of) Bishop Auckland | Fletch SV | Pennine Massive | 1 | 18-04-07 08:52 AM |
definitely an oldie | embee | Idle Banter | 3 | 02-10-06 09:46 PM |
