Old 29-07-20, 11:17 AM   #21
DamoK4
Default Re: Nightmare day
Can anyone advise me on the noise in the forks? It’s sunny this weekend
DamoK4 is offline   Reply With Quote
Old 29-07-20, 03:58 PM   #22
NedSVS
Once the fork is compressed a little the small spring, the one that stops the forks extending and hitting the fully extended limit with a bump, is free to slide up and down. Is that it?
Old 29-07-20, 05:20 PM   #23
DamoK4
Oh right, I hope so, the spring, oil, washer and spacer is out and it doesn’t make any noise. It’s when I bottom the fork out and tip it upside down something slides. Is that the little spring? I have a garage taking the seized screw out tomorrow so I can get it sprayed and back together Friday if it’s normal
Old 29-07-20, 08:34 PM   #24
Adam Ef
Adam Ef's Avatar
There's a smaller spring around the rebound damper rod... to stop forks bottoming out as mentioned above..
Past:
Old 29-07-20, 10:04 PM   #25
DamoK4
Cheers fellas
Old 30-07-20, 07:47 PM   #26
DamoK4
Got the bolt drilled out and re tapped. Sanding the forks now. Will turn some spacers tomorrow
M62 nightmare missjhb Idle Banter 11 07-12-12 10:09 AM
Worst Nightmare... jonny.boyd Idle Banter 32 09-06-11 08:08 AM
2 up nightmare - Help! Jackie_Black Bikes - Talk & Issues 17 20-02-09 02:19 PM
Nightmare of a k1 philbert SV Talk, Tuning & Tweaking 9 02-01-09 07:21 PM
My Thruxton nightmare... DaveW_42 Photos 29 21-12-08 03:55 PM
