#21 | |
Cooper grease has a high failure temprature than normal grease. Cheers Mark.
#22 | ||
#23 |
ok -
so what about pinking and knocking. what to they mean ? and how do you know the difference between the two ? also - how do braided hoses work over standard ones? how can you tell when you need new brake fluid ? |
#24 | |
Pinking is pre ignition. When the fuel combusts before the piston reaches top dead centre of it's travel. It is caused by bad timing, poor quality fuel amounst other things. I think knocking is the same. Braided hoses are just normal rubber hoses with a metal sheath or "braid" around them. Rubber hoses will expand slightly when pressure is applied internally. Ie. when you pull the brakes. The metal sheathed ones do not expand as much, making your brakes less spongey and more snappy. You can tell when you need new brake fluid when it starts going honey coloured in the reservoir. The fluid gradually breaks down over time as it is repeatedly heated and cooled. Brake fluid is also hydroscopic so it absorbs water. This is not good as water expands when hot and causes bubbles in the brake fluid, giving you at best a spongey lever. At worst the moisture will seize your caliper pistons. It is a relatively easy job to bleed the brakes if you have the right tools. My entire brake bleed kit probably cost £8. |
#25 |
When you squeeze your brake lever, it forces brake fluid from the reservoir to the brake cylinders - this pushes the piston onto the pad, which is what makes you stop (hopefully).
Standard hoses, which are made from rubber tend to expand a bit when you squeeze the brake lever due to the increase in pressure. Braided hoses are shrouded in a metal sleeve, which prevents the hoses from expanding - therefore all the pressure is applied directly to the piston, rather than losing a bit in the hoses. I think recommendation is to change fluid every 4 years, however if you are a heavy brake user (e.g. lots of track days) then you will need to do it more regularly. It will probably need changing as soon you begin to notice a change in your braking performance (e.g. lever pulled back to the bars and still not stopping!) - assuming that pads/calipers etc are all ok.
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#26 |
I've got 2 hours spare tomorrow, can I fit my K3 cams, replace the rear subframe, get to HG and pick up a new bottle of Scottoiler 365, fit my new double bubble screen, clean up my spare wheel, replace the rear brake lever, order some british racing green and some silver paint plus primer and clear coat, prep all the rest of my panels, replace my choke cables, fit the bits of my Dynojet kit that aren't main jets, document the Veypor fitting and shakedown, check my valve clearances, lube all the other cables and find out what's wrong with my Glowgauges tach gauge and fix it?
#27 | |
#28 |
I think it took 2 hours to explain everything to bikageboy
![]() ![]() I always thought of doing one of those bike mechanic courses.... ![]() |
#29 | |
#30 | |
50 free Hours with AOL | Richie | Idle Banter | 6 | 01-11-08 08:59 AM |
These will keep you amused for hours :) | Blue_SV650S | Idle Banter | 0 | 14-05-08 04:59 PM |
4 hours | Dicky Ticker | The Essex Lounge | 3 | 06-09-06 11:30 AM |
Off to France in 24 hours..... | 454697819 | Bikes - Talk & Issues | 7 | 13-05-06 09:43 AM |
Two hours to go... | markfc | SV Talk, Tuning & Tweaking | 5 | 04-03-05 02:15 PM |
