Old 09-08-05, 03:37 PM   #21
M.C.
M.C.'s Avatar
this does p!ss me off too my CBR would strat with just the button but all i do if i'm standing up is push the clutch in with my leg and then start the bike if my hands are full
M.C. is offline   Reply With Quote
Old 09-08-05, 04:15 PM   #22
i will be doing this mod as it p@sses me off to!
Old 09-08-05, 06:27 PM   #23
Take it a step further and remove the switch too, it lightens the clutch action a little. TBH I think you've got to be a bit mentally deficient to start the bike in gear anyway And it's one less switch to go wrong and leave you stranded.
Old 09-08-05, 06:46 PM   #24
Robw#70
But what about the 'Start-up' map that most injected suzuki's go in to when the clutch is pulled in.
GSXR1000's loose 500rpm from the top end before the limiter when the clutch switch is looped.
A few years ago in the superstocks there was a suspicion over a couple of bikes that made more power and revved higher, turned out 90% of the Gsxr's had the clutch switch looped as part of the std race prep and the ones that made more power were std
Since then I have avoided looping things on injected bikes without being 100% on its consequences
Old 09-08-05, 07:15 PM   #25
SPeeeeDY
I am not 100% certain on how it all works, but if you start a bike from cold and leave it to warm up in neutral it slowly causes internal engine damage.
You are supposed to start the bike and set off within around 15seconds
I am almost certain this was printed in the MCN a few months ago, but it may have been one of the magazines
so starting the bike before you put your lid and gloves on is deffinatly not to your advantage, well not to your bikes advantage anyway
SPeeeeDY
Old 09-08-05, 08:48 PM   #26
ophic
ophic's Avatar
my old kawasaki used to have the clutch linked to the sidestand by a cable. Now that was marvellous as you could amaze ppl my flicking the sidestand up... seemingly magically. And achieved the same as the clutch switch - stopping one from riding off with the side-stand down.
It was a kick start anyway so it wasn't so important if the clutch was in or not for starting.
Silver SV650SK3, Fuel exhaust
Old 09-08-05, 09:06 PM   #27
jonboy
Providing that all the engine components get sprayed with oil (the engine's idle speed is high enough) then there really is no problem. Only on a brand new bike when the pistons are still bedding in will you likely suffer from glazing of the bores which is best avoided.
If you don't give the engine time to circulate the oil and the internals at least achieve a working temperature then you're going to cause damage riding off too soon. A good thirty seconds is, I suggest, the absolute minimum when riding off from stone cold.
Old 09-08-05, 10:25 PM   #28
21QUEST
21QUEST's Avatar
Just do more exercise on the left wrist .
Who are you calling mentally deficient . I always start my bike in gear as I always leave it in gear when parked. I do pull the clutch in though before starting Mr ..wind .
Ben
Nemo me impune lacessit.
Old 10-08-05, 07:50 AM   #29
For the FI bikes, (the 1000 anyway, don't know specifcally about 650s but I'd be surprised if there weren't a similar system), this is a good reason for not looping the switch out.
When cold pulling the clutch raises the tickover about 500rpm, when hot the clutch switch operates a limiter that caps the revs so it can't be over-revved accidentally, if the switch is bypassed the revs will be capped artificially and the bike will be down on power in a similar way to the GSXR mentioned.
The TRE mod on FI bikes, (again 1000s certainly, likely 650s too), disables the cold start/running fuelling and ignition map, such that the bikes don't run well until hot, this is why many people, (myself included), have switched the TRE. With a cold engine in town in cold weather, the bike doesn't tickover right and can run awkwardly with the TRE engaged.
Old 10-08-05, 05:12 PM   #30
you know fine well what i mean
Pulling a bike mechanic and other things that happened on my rideout today Graciepants Idle Banter 184 12-04-09 03:49 PM
Replaced Clutch Rod, now bike wont start.. skydivincoastie SV Talk, Tuning & Tweaking 6 12-08-07 08:06 PM
Clutch start switch.... craven2k SV Talk, Tuning & Tweaking 4 17-04-06 06:54 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
Pulling wheelies and bike wear SV_Rider087 SV Talk, Tuning & Tweaking 13 22-09-04 09:14 PM
