Old 19-08-05, 04:24 PM   #21
Nekkid
Originally Posted by Spiderman
if, like some on this site, you are more inclined to go with 70%rear and 30%front in the dry.
I think those people, whoever they are, need more training.
As for leaning in the wet, I'd recommend not even thinking about it. Do what feels safe. Trying to increase the anglge will only lead to a spill. It takes a while to get used to it, don't try and speed it up.
Old 19-08-05, 04:29 PM   #22
jonboy
I must need more training then as I'm a renowned rear braker - maybe that's why I'm so slow .
Old 19-08-05, 04:30 PM   #23
Cazza
In addition to all the bike-riding techniques... don't forget to wear appropriate clothing. There's nothing more miserable (and distracting - so therefore dangerous) than having cold soggy hands / legs / bottom etc.
Cover-up (and wrap-up in winter) so you're dry and toasty - and you'll have fun!
Old 19-08-05, 04:42 PM   #24
mysteryjimbo
Whoops double post
Old 19-08-05, 04:42 PM   #25
mysteryjimbo
My 2p worth.
I find i always lock the rear when braking in the wet. maybe an adjustment of your braking balance for wet riding is a good idea if, like some on this site, you are more inclined to go with 70%rear and 30%front in the dry.
However i would also advise that you make the change (and practice) in the dry till you have the braking more at 70%front and 30%rear. Changing the manner in which you normally apply your brakes can be a bit hairy the first time you try doing something "diffrent" from your normal way.
Personaly i always do the 70f & 30r so its been a little easier for me to just stay off the back brake altogether in the wet.
hth
IMO you arent braking hard enough if you can use your rear brake. If you were your rear would be in the air!
Use more "even" braking in the wet, say 50.50. I can say this with confidence and 365 days a year riding. So, to date around 1500 days.
Old 19-08-05, 05:34 PM   #26
Kate
According to the DAS instructors its supposed to be 70/30 in the dry and 50/50 in the wet on the brakes, or thats what my ones said anyway.
I've found that smoothly does it seems to do the job. You are aware of the hazards already and if you can't avoid a manhole cover then its not the end of the world if you have to go over it.
One thing I have noticed is that when I come to a stop and put my foot down, quite often the ground is so slippery that my foot skids, easily sorted by again, being smooth and relaxed and not just stomping the foot down.
Old 19-08-05, 05:40 PM   #27
Warren
surely it will be different for every bike. all depends on how the bike is set up.
someone correct me.
Old 22-08-05, 12:00 PM   #28
Kylie
Kylie's Avatar
Cheers for all the tips, rode much more confidently on the way home, going as fast as the cars on the roads round most corners now, which is the main thing (I'm not mad on being rear-ended). Its a matter of developing a trust for your tyres I guess.
Changed my mind on the rain on visor problem though, that got more of a hassle when it got dark too. Maybe need to stitch a chammy into palm of left hand glove....
Kylie is offline   Reply With Quote
Old 22-08-05, 04:09 PM   #29
Mr Toad
Originally Posted by jonboy
Trust uncle jonboy, take it easy in the wet or you'll come off .
Where was this advice when I needed it
Old 22-08-05, 04:23 PM   #30
Muttley
Is that 70 front or 70 rear?
I was always told (and taught) to use (in the dry) 70 f / 30 r, as you have so much more braking power / grip through the front brake / tyre when braking.
If the rear was meant as your primary source of slowing down then surely the front disks would be smaller and larger at the rear.
I try not to touch the rear brake in wet (unless I'm doing a slow manouvere) until I have done most of my braking, as it is so much easier to lock up.
Riding Gear for Rain sv650sfan Riding Gear 8 19-08-08 08:23 PM
Rain Rain, Go Away... the backup plan! Ping 2007 Annual Rideout 39 29-06-07 09:31 AM
rain Dave The Rave Pennine Massive 4 25-06-07 09:56 PM
Riding in rain plowsie Bikes - Talk & Issues 49 01-06-07 11:05 PM
Riding in rain localhost Bikes - Talk & Issues 6 19-05-06 10:10 AM
