Old 16-01-06, 01:35 AM   #21
Valman
Originally Posted by Cloggsy
Originally Posted by northwind
As far as the Suzuki bungs go, there's been reports of them breaking in 0mph drops...
That's what I was talkin' about here...
The standard ones are 5h1te, the snap as soon as look at 'em ('eh Captain Nemo?)
The good Capt. Nemo's bike fell off its side stand & mashed his lowers - the standard Suzuki bung just snapped off, doing absolutely nothing to save his fairing
Christ knows what'd happen if you came off at speed
I can tell you exactly what happens as I seem to be one of the privileged few who’s actually tested them out, lucky me.
Even though my slide was very low speed I found the mount basically snaps back into the frame at the weld, pulling the bung with it. This causes the bung to pull the fairing towards the frame, cracking the fairing in several places around the bung hole and causing the fairing to scratch the frame as well as the covers on the side of the engine , while the fairing hits the ground and gets scratched up too. The bar-end, exhaust, indicator and top fairing are then left to absorb the rest of the slide and hopefully bring the bike to a stop without even more damage.
I also have a crack on the fairing on the other side of my bike coming from where the LHS bung is mounted that appeared after 6 months of owning the bike , the dealer blamed my off even though that happened on the second day of owning the bike.
So I think I would have been better off without the Suzuki crash bungs as I probably would have ended up with less damage to my bike, the fairing would have probably still been scuffed but I certainly don’t think that the cracks would exist, and I think it’s all down to how the bungs are mounted.
I can see Chewy’s logic in making the bung shorter though, people who have not got the Suzuki bungs seem to come out better with just the silver disc on the fairing on the same mounts even at higher speeds, so it might work and if you’re skint then let’s not forget these are much cheaper than buying R&Gs. However, I think that even the Suzuki bungs would work fine with better mounts as mine was barely worn and so really it’s the mounts that need changing .
Old 16-01-06, 08:37 AM   #22
Foey
When will the crash bobbins be for sale, interested in a pair for my K5.
Old 16-01-06, 10:03 AM   #23
Captain Nemo
Chewwy the bungs look sweet.
unfortunately the problem with the suzuki bungs is the fact that they mounted to the fairng brackets which have the structural integrity of old kebab meat. they are cantilevered off the engine mount, and dont transfer the force directly to the frame or throught the bolt, the curvy bracket just ends up bending or snapping
mine fell of its stand and snapped the fairing bracket at the weld, suzukis answer to this was that the bung stopped any damage to the fairing so it worked, the fact that it snapped with very little force applied was of little interest to them. if it had been dropped at speed the snapped bracked would have caused the bung to push against the fairing and snap it.
the R+G's which i replaced the oem ones are amazing they look like you could smack em with a hammer and cause no damage.
chewwy if your bungs fit into teh recess in the fairng lower the they should be a direct repacement for the r+g ones as well, as long as the bolt is the same thread i suppose.
good work fella
Old 16-01-06, 01:41 PM   #24
ujoni08
Default crash bobbins
Chewy, I'm keen. I have an SV650S K5 with fairing lowers. I'd be interested in the fairing- and axle-bobbins. I have mirror extenders from you and they're very good.
Jon.
Old 16-01-06, 05:12 PM   #25
leegriffiths128
Will these be anygood for my K3 "S" model...its totally standard apart from a Fuel exhaust.
I was first to put my name down for em' but now it looks as though they'll only be of benefit if you have fairing lowers.
Just figured that after riding 8 years the seasons through then my luck is bound to run out soon and I'll have a spill or drop her. You guys all seem to have some form of protection on yer bikes so thought I'd join ya.
Sorry to Chewy if I've messed you about...
P.S Anyone have medication for the following complaint.........turned into the frowned upon throttle blipper since the new exhaust
Old 16-01-06, 05:46 PM   #26
ophic
ophic's Avatar
I think its terminal
Silver SV650SK3, Fuel exhaust
Old 16-01-06, 05:50 PM   #27
leegriffiths128
Did you manage to get yours fitted Ophic ?
Sorry for straying off the topic..
Old 16-01-06, 06:02 PM   #28
fizzwheel
fizzwheel's Avatar
Same thing happened to Liz's K5 when it got dropped at low speed
The whole way the Suzuki bung mounts to the frame IMHO is utter sh*t, the bung itself held up well, however the bracket must be made of cheese...
Old 16-01-06, 06:04 PM   #29
ophic
ophic's Avatar
oh yes i've been winding up the CCC fellas cos it was so easy to fit
Old 16-01-06, 06:49 PM   #30
leegriffiths128
And what do you think of it ? Hows it compare to the CCC soundwise ?
I'm getting plenty of pops n' f*rts from mine...glorious ! :P
Fairing Replacement/Change fri-sv SV Talk, Tuning & Tweaking 2 15-07-08 10:04 PM
Suzuki OEM top box & rear seat replacement Dysparunia SV Talk, Tuning & Tweaking 5 08-01-07 05:54 PM
2006 Suzuki Lower Fairing w/ Frame Sliders (crash bungs) Maestro Bodywork 1 29-11-06 08:35 AM
Suzuki SV replacement bombshell! Peter Henry Bikes - Talk & Issues 43 29-09-06 12:40 PM
Replacement fairing alex.j SV Talk, Tuning & Tweaking 4 02-09-06 02:49 PM
