#21 | |
the valves get also hotter and you will need other "ignition candles" (=bougies) sorry for the offtopic btw, but what does "AFAIK" mean? |
#22 |
Pinging, possibly? Advancing the ignition can have a similiar affect to raising compression. I was advised at the time that normal pump should be absolutely fine- though I use BP Ultimate usually anyway, since I'm easily impressed by marketing.
AFAIK means As Far As I Know.
#23 | |
![]() sorry to correct you northwind, but AFAIK i was told an a Belgian forum that advancing the ignition has nothing smiliar to raising compression, because you don't change any geomitry of the cilinder. but the advancing causes more fuel to burn => more heat. I can be wrong... I presume on your repley that you have done this modification? do you feel a big difference? as I can see on the graf, you get a lot more power in the lower rpm's, does that effect your driving, I mean when you advance from a stop... do you feel any difference when you get 95 in stead of 98 fuel? |
#24 |
I believe the term is knocking (or pinking) when the fuel ignites before the spark fires.
http://en.wikipedia.org/wiki/Talk:Engine_knocking Changing the igniton advance should not create knocking. It does not burn more fuel, it only starts the ignition earlier. If it is advanced too far, it can have an effect like knocking. If the spark fires ATDC, the piston is already travelling down on the power stroke by the time the fuel combusts. This means that the compression has been reduced, and less power is achieved. If the spark fires BTDC (which it should) when the fuel combusts the energy released forces the piston down on the power stroke at maximum compression. By altering the ignition timing, you can control where the pistion is when the fuel combusts. |
#25 | |
![]() But with regard to the results, it's very noticable in the low revs. I'm skeptical about whether it made any difference up top, but the difference in the lower range is very noticable. It suits the way I ride- I tend to ride the midrange a lot day to day, so the extra torque is very welcome. I can't remember if I already said, but they say that with a more tuned engine, less advance is better than more for peak power. Apparently the advancer will now be costing me a horsepower or two at peak- but for the benefit in the midrange, that's more than worth it IMO. If I got a new SV, I'd do the cam swap and ignition advancer before the cheque had cleared ![]()
#26 |
Oh yeah, you asked about the octanes... I always use premium when it's available, so I can't really compare properly. The only time I use standard, it tends to be from dodgier petrol stations
#27 |
thanks for the response.
i think i'll go for one too... ![]() but i will make it myself if i can still find the dimentions of the key. i found them on a American forum (www.socalsvrider.org) if i remember... that will save me some money i think ![]() |
#28 | |
#29 |
part no. 11483-19F00
the magneto cover gasket |
#30 | |
ignition advancer rotor puller | svryanpompy | For Sale - SV's and SV related items | 0 | 05-05-07 10:06 AM |
rotor puller | svryanpompy | Stuff Wanted | 17 | 17-03-07 07:48 AM |
I need a rotor puller tool | svrash | SV Talk, Tuning & Tweaking | 8 | 22-03-06 03:58 PM |
Who's got my rotor puller? | northwind | SV Talk, Tuning & Tweaking | 4 | 03-01-06 03:58 PM |
Rotor Puller Tool | TSM | SV Talk, Tuning & Tweaking | 6 | 07-12-05 06:24 PM |
