#21 |
My 2 bobs worth on the "Brown and yucky" downside.....
Can't you add trace dye like we have at work to give you a nice "ooo that matches my leathers and paint" kind of girly co-ordinated feel ![]() Cheers |
#22 |
Oh yes, one other tip.
When drilling plastics you usually really need a zero top rake angle drill-bit. You can do this by hand stoning a normal twist drill, parallel to the drill on the front cutting edge. It turns it into a "scraper" rather than a wedge cutter so it reduces the grab when breaking through, and less likely to crack the plastic. Also chamfer the edges of the holes generously with a countersink (or even a bigger drill-bit) to reduce the stress at the corner due to bending when tightening the screws so it's less likely to crack. |
#23 |
Great stuff embee! You should write a book!
I make my own tools sometimes and am aware of the problem you brought up. I once bevelled in the front cutting edges and ended up with a center point and two scraping edges. It worked a treat. One must be careful not to overtighten as you said. And why wouldn't you do this cool looking mod when you've got the expertise and tools for the job? |
#24 |
As far as I remember you could get these covers off some chap on ebay in germany. But I have seen any for a couple of years.
Transparent clutch cover 2 | 21QUEST | SV Talk, Tuning & Tweaking | 34 | 05-08-11 10:45 AM |
bloody clutch cover | AndyBrad | SV Talk, Tuning & Tweaking | 42 | 03-03-09 08:22 PM |
Clutch Cover | carsounds_dan | SV Talk, Tuning & Tweaking | 17 | 12-06-08 04:27 PM |
Clutch cover. | scottjames | SV Talk, Tuning & Tweaking | 8 | 16-04-08 11:30 AM |
clutch cover leaking | habbie | SV Talk, Tuning & Tweaking | 0 | 06-05-07 02:07 PM |
