Old 16-10-06, 06:02 PM   #21
Beenz
This looks really good. That zorst could do with shedding a few pounds though. But then again, so could I.
Old 16-10-06, 10:51 PM   #22
Horney
Thats next on the cards, but I'll wait til after the winter.
Old 17-10-06, 07:55 PM   #23
Pm or e mail.. "courdelion" ..
Richard- as is his real name- had the very same on his.. b4 he went to the dark side of the gixxer boys... -
he will tell ya if his flashed fast.
I followed him on AR05.. and couldnt see them anyway !!!! oops.
Old 17-10-06, 08:36 PM   #24
Pervytwin
An updated flasher relay will solve the flash rate problem. They cost about £20 though and can be a pain to fit as you need to splice the wires into the original flasher unit.
The reason behind it is that LEDs use less wattage so the resistance is less, therefore the pulses come faster. The flasher unit will solve this for you in one swoop. If you're good with electronics and have a wiring diagram it can be done in less than 30mins.
Motrax do the unit and it's the universal one you need.
Old 17-10-06, 09:03 PM   #25
zunkus
You need 10 ohm resistors. I'd prefer to have them as high watt rating as possible, 25W or more as otherwise they will get real hot and eventually open circuit. Be sure to connect these in parallel to the LEDs, not in series. If you connected your existing resistors inline (in series) they won't work. Connect resistor between the (+) indicator feed supply and the earth (-).
Old 18-10-06, 04:07 PM   #26
Moo
Sweet
Pimped my **** cuffy Photos 18 18-09-06 02:41 PM
Gave her a nice wash...hada nice ride to a bridge ruff_ryder Photos 17 27-08-06 10:55 PM
Arsety **** **** Carsick Idle Banter 8 15-08-06 04:04 PM
Nice **** northwind Idle Banter 4 02-04-06 01:16 PM
My new **** end looks great! quikstu Ancillaries 4 17-04-05 12:49 PM
