Originally Posted by Razor
Has the pointy got the same drain hole on the off side of the front cylinder as the curvy?
Yep sure does.
Ah well then, Stu you just need to give your hole a good clean
I can go with that - tht's what caused my issues a couple of weeks ago. Rode 10km's on just the rear cyl, one squirt of WD40 and hey presto working bike. Poke the hole with the straw (misquote at will
) and all of a sudden the side of the engine was awash with Wd and water...
Went home and ordered at fenda extenda - fitted it last week, but not ridden trhough rain again yet so I can't comment on how effective it is... (Also the problem above was the first in over two years and I've ridden in much worse weather than when it stopped
Stu
