Old 21-11-06, 11:50 PM   #21
Robw#70
Is it a genuine clutch? If so are the steels correct as suzuki use different thickness on different bikes, so do barnett and if its Ebc throw it away. use the box it'll be more reliable
Check the overall stack height and thrust bearing assy properly located
Old 22-11-06, 12:12 AM   #22
Damoulianos Marios
This surely sounds stupid but I couldn't figure out what this worm you guys are referring to is. I'm having same problems with my clutch...
Old 22-11-06, 12:30 AM   #23
BILLY
It's under the front sprocket cover I think it's called the clutch activator!!
Old 22-11-06, 01:11 AM   #24
21QUEST
21QUEST's Avatar
You think? .
It's called the clutch release assembly
Thanks for the extra pointers Rob. As far as I'm aware the plates are OE. bought the bike with quite a bit of work done on it by JHS racing so might not be stock(possibly barnett if not)
@ EBC
Ben
Nemo me impune lacessit.
Old 22-11-06, 09:06 AM   #25
Stormspiel
BLATANT PLUG *If any of you can't fix yours i have a complete clutch i'm willing to part with*
Old 22-11-06, 10:18 PM   #26
Robw#70
Just thought, the other thing to check is the clutch lever as pattern ones can have a different pivot/mounting point to OE
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
clutch kit sv650nutter149 For Sale - SV's and SV related items 0 25-06-07 03:08 PM
clutch has had it! socommk23 SV Talk, Tuning & Tweaking 8 10-03-06 06:21 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
