Old 27-11-06, 09:21 PM   #21
Stu
Trinity
Stu's Avatar
Originally Posted by 21QUEST
the correct size(120/70 and 160/70).
Surely 160/60
Old 27-11-06, 09:23 PM   #22
21QUEST
21QUEST's Avatar
the correct size(120/60 and 160/60).
Surely 160/60
Just checking you were paying attention at the back
Ben
Nemo me impune lacessit.
Old 27-11-06, 09:31 PM   #23
Stu
Trinity
Stu's Avatar
at the back - back tyre
:rofl:
:rotflmao:
:lmao:
Old 27-11-06, 09:33 PM   #24
Stu
Trinity
Stu's Avatar
And that sneaky edit Ben has ruined my joke, 120/70 is usually OK?
Old 27-11-06, 09:51 PM   #25
21QUEST
21QUEST's Avatar
As for the 120/70 , if someone were to ask me I'll say stick to the 120/60 unless you have specific issues you wanting to address JMO.
The is a thread some where were it was discussed at length I seem to remember.
Ben
Old 27-11-06, 10:31 PM   #26
Originally Posted by RandyO
4.5" rims are designed for 150mm tires, 160s are a squeeze, even a 160 is happier on a 5" rim,
a 180 needs a 6" wide rim without it, you asking for bead seal failure when your leaned over the most
Depends, it used to be possible to say such things, it certainly isn't so any more. Since the bigger-is-better obsession with tyres many quoted tyre sizes can realistically be considered as part numbers, some makers habitually overquote sizes. There's no shortage of 160 section tyres that are fine on SV rims and not pinched at all, most, not all, 170 and 180 tyres are as near as makes no difference and fit both 5.5" and 6" rims.
All the same, an SV on standard wheels most certainly should not be wearing a 180 section tyre, that would require a 5.5" or 6" rim.
Old 28-11-06, 11:21 AM   #27
Blue_SV650S
Ben
Indeed, for the road I'd want the 60
aforementioned thread:- http://forums.sv650.org/viewtopic.ph...&highlight=120
Old 28-11-06, 12:09 PM   #28
Flamin_Squirrel
Ben
I'd say go for the /70, just because it's worth trying
Old 28-11-06, 01:27 PM   #29
Blue_SV650S
What do you expect to achieve with a 70 section?
Old 28-11-06, 01:37 PM   #30
Flamin_Squirrel
Main reason is it means I don't run out of tyre on a track day. Since I havn't noticed any advantage to having a /60 tyre, I'll always go with the /70.
Tyre Advice Please cmc1 SV Talk, Tuning & Tweaking 9 21-06-08 02:50 PM
Tyre advice please Malt Tyres 20 03-09-07 06:39 AM
new tyre advice barmy.biker Tyres 1 05-07-07 03:46 PM
Tyre advice Shellywoozle Bikes - Talk & Issues 17 18-09-06 07:17 PM
Tyre Advice Plz... WelshWop SV Talk, Tuning & Tweaking 7 20-04-05 10:33 AM
