Old 27-01-07, 02:02 AM   #21
ejohnh
Originally Posted by Warren
Originally Posted by Baph
Originally Posted by jambo
Ok a quick point, starting your bike takes a large lump of the charge out of a battery. Riding puts it back in, I have heard a ball-park figure of about 10 miles to put all the charge back in, I'd assume a little less would be fine, but I've bump started a bike from flat and seen it run 6 miles, park up and be unable to start again without another bump (that was with a new battery) so if you're starting every mile and a half you may just not be putting enough back in.
Exactly my thought as soon as I read Warren's post explaining the situation.
Short runs will never be good for the battery, or the rest of the engine to be honest. Buy a battery, leave the bike at home, and walk the 1.5miles :P
i would love to, but taking the bike means i get an extra 30 mins in bed.
cool, new battery arrived today, which is nice.
now do i need to charge it or prepare it in any way before sticking it in the bike ?
ive got a 60 mile ride tomorrow
Sounds like it always was the battery. 6 years is an old battery. When you dump the acid into the battery(presuming that is what you got(a kit)) there will be a lot of charge in there. I changed my battery last week and I put it on charge for an hour. I could see it was full of juice though because the charger could only pump less than an amp flow into it.
John
Old 27-01-07, 10:59 AM   #22
Warren
Originally Posted by roger
I agree, it's the battery.
But regs are prone to failure, and...
It's unusual, but the problem can also occur with a tired starter motor.
Basically the starter draws way too much current while your battery is OK, so the headlights are bright when the engine isn't running (battery voltage about 11.5 volts or so); but when you try to start it the voltage drops dramatically.
You can check the starter motor, it's in the electrical section of the workshop manual.
Brushes are available, but the rotor cannot be replaced as a spare. Buy the whole thing from a breaker.
i have a CBR,
that is something i have thought about, but straight after charging the battery,. the starter sounds fine.
my voltage drops to 7.5 across the terminals when i start the bike.
Circuit Gearing chardy Mini-Twins 3 12-04-09 06:52 PM
charging system check - values steveg SV Talk, Tuning & Tweaking 4 17-02-08 07:21 PM
Brands GP circuit Jdubya Track Days 2 12-06-07 02:52 PM
Crash.NET - Circuit-by-circuit with Dani Pedrosa. NewsBot News 0 04-04-07 04:10 PM
Weird charging circuit values andyb SV Talk, Tuning & Tweaking 11 05-04-06 11:19 AM
