#21 |
Massive amounts of analysis go into the design of any suspension. Look at the RC-51, as an example. Both HRC and folks like Dan Kyle racing design replacement linkage components to alter the rear linkage to do things like improve traction characteristics - to noticeable improvement. These are not massive sized changes.
Do a search for Tony Foale. He sells a suspension design/anaylsis software product. I purchased this package to analyse the changes that came with putting the RC30 swing arm on my SV. I needed a significantly different spring rate and valving curve to 'make it work'. You'd be shocked (pun intended) to learn how big a difference a little change can make. I'll offer this: You are at risk of unknown behavior/results when you mix parts from one bike with another - particularly suspension parts. The linkage rates are different, the shocks (regardless of the budget to which they are built - are designed to 'work' with that linkage ratio, etc. For example, you may end up with a mix that has too steep a rising rate for the shock which causes the suspension to get deeper into the valving than is originally desired and cause you to 'all of a sudden like' have a very stiff rear suspension. Not the sort of thing you want to find out when you're cranked over and hit an unseen bump. Yes, I know were talking degrees here and folks like Mr. Rossi and Mr. Hayden are well ahead of us in their ability to detect a 'hey, that's not right' setting but the FACT remains: You risk 'negative impact' to your safety (and others) when you mess with anything that impacts your ability to control your motorcycle. Certainly there are positive impacts as well. Just because a part can be made to fit doesn't mean it should be made to fit. All I'm saying is that YOU ARE RESPONSIIBLE FOR KNOWING that what you're up to is moving the meter in the desired direction. *steps off soapbox* |
#22 |
Ubique
Thats what, umm, I was, erm trying to say in, umm, a roundaboutish kind of way sort of thing
![]() If you cut thru all the scenarios and things I was essentially right. WOO-HOO ![]() ![]()
Jesus loves you. Everyone else thinks you're a pillock |
#23 | ||
![]() ![]() ![]() ![]() Northy - Thankyou for you r generous offer ![]() ![]() Oh and I don't need selling on the fact of how good Ohlins shocks are ... I raced on them for years ![]() ![]() Quote:
If I put it on and it wasn't working how I desired, even after messing with the adjusters then I'd ditch it ... the standard shock is so poor even a non-optimal usage of a better shock gives better results ![]() |
#24 |
Yeah, something like that's probably about what I'd expect... But since it'll cost me that do do anyway I was thinking we could split it or something
#25 | |
The fact is, the SV suspension's cheap and nasty. The forks have more in common with door closing mechanisms than with modern suspension, and the rear's basically misspecced for the average british or American rider. I shudder when I hear about 200 pound riders on stock SVs... You can make huge changes to it without incurring any negative results, because you're not shooting for perfection- just improvement. The 636 shock swap's very far from perfect, but for most of us it's further from dreadful than the stock unit ![]()
#26 | |
![]() If I get into minitwins (i.e. do more than a round or two) then I'd be after a race shock, but to be honest for trackdaying the ZX option is fine ... I mean jez, I am running 2nd hand tyres .... somone else has deemed them too knackerd to use on their bike ... its not like the bike is ever going to get full benefit from a rear shock if I am still using sha66ed tyres!!! ![]() ![]() |
#27 |
Jeez Blue, you sound like a cheap date
![]() ![]() ![]() Word on the street is, a guy just came into some money. You tight git ![]() ![]() Ben |
#28 | |
![]() ![]() I am not a rich man (far from it), and therefore I try to allocate what I have in the wisest way so it goes the furthest and I get the most benefit from it ... at the end of the day remember my budget means that I have crash damaged curvys that I got cheap and spent time resurrecting and making the best of myself by sourcing 2nd hand parts ... not the latest K7 fully tricked out by Crescent Suzuki!!! ![]() If I was rich I wouldn't have to make any decisions, I'd have the best and I'd have it all ![]() ![]() I try and do the best I can with what I have ... surely that is only logic, whats the point in spending £'000s tricking my SVs out then having no cash to actually use them? Or do anything else extra curricula with my life??? My cost-benefit analysis says that an Ohlins shock isn't worth the investment at this time (I might at a future date if some of the variables change). I have the cash yes, so I am being tight here??? perhaps??? you might see it like that?? as may others?? ... But the thinking man would see it as logical!! ![]() |
#29 | ||
![]() ![]() ![]() Ben ps: I dare you to buy four(not ten) Ohlins shocks and since you only have three SV650s I'll make sure the fourth doesn't go to waste ![]() |
#30 | |
![]() ![]() As for blagging a shock ... lol, now think about it I am struggling to justify the expense for my own trackbike/s, I'd never be able to justify it for my roadbike (that I only use for commuting), let alone a spare ![]() ![]() |
Has anyone made home made abba stand adapters? | monkey | Bikes - Talk & Issues | 9 | 31-03-09 10:00 PM |
Which Shock for curvy? | SAMMY650 | SV Talk, Tuning & Tweaking | 19 | 09-06-08 06:51 AM |
Curvy Shock | aarond | Stuff Wanted | 5 | 19-05-08 10:58 AM |
Home made undertray for curvy | sv_rider1990 | SV Talk, Tuning & Tweaking | 7 | 31-03-08 06:50 PM |
curvy tail tidy made a bit easier... | philh | SV Talk, Tuning & Tweaking | 14 | 06-04-07 07:39 AM |
