Old 13-02-07, 02:52 PM   #21
Law
Originally Posted by hovi5
Originally Posted by Ping
Kewl If you're going to use that as your avatar though you'll need to shrink it...
"its width can be no greater than 140 pixels, the height no greater than 150 pixels"
Space hog...
Edit: I just looked at the filesize...
filesize....................how?
& is it too big?
Hovi5, it's massive, it's not going to fit.
The filesize is about 20 times too big.
Old 13-02-07, 03:02 PM   #22
hovis
Space hog...
& is it too big?
i know?..............how do i make it smaller?
Old 13-02-07, 03:31 PM   #23
Jabba
Half the width and half the height and you'll have a file 1/4 the size.
Remember that every frame you add is the same as adding another image to your file.
Old 13-02-07, 03:41 PM   #24
hovis
but then you wont be able to see it & it will still be 75kb
Old 13-02-07, 04:04 PM   #25
Grinch
You have 45 frames for 2 images... just a sec and I will sort it.
Old 13-02-07, 04:11 PM   #26
Grinch
check your mail.
Old 13-02-07, 04:15 PM   #27
hovis
i did it........................
but i will check mail now to see it done propaly
Old 13-02-07, 04:18 PM   #28
hovis
this is the one you sent but when i save it ,it stops flashing?
Old 13-02-07, 04:52 PM   #29
Jabba
The file in the post above is a .jpg file. This format doesn't support animations.
.gif is the only file format that web-browsers can read which supports animations.
Also, you need to sort out the timings in the .gif file you are using as your avatar. It's rolling over a bit too quickly and viewers can't see the alternative image. We can in Grinch's avatar.
Old 14-02-07, 08:37 AM   #30
hovis
NOPE.............. i got the timings bang on IMO
sticky out tounge smiley
my Avatar bad-sv650 Idle Banter 12 05-03-08 12:24 AM
my avatar kwak zzr Idle Banter 18 01-08-07 09:09 PM
