Old 05-03-07, 05:51 PM   #21
hovis
Default Re: Upgraded headlight bulbs
Originally Posted by jonhunt View Post
yes ............
Silver Stars are good, but the new x-treme power are better at the periphery of the beams. Just swapped out silver stars for x-tremes in me xtrail (one blew so was an excuse). Lots of dark lanes round here and good lights are a must.
Old 05-03-07, 05:59 PM   #22
ejohnh
Originally Posted by hovi5 View Post
yes ............
Blimey! £24+ for one bulb?
Old 05-03-07, 06:02 PM   #23
hovis
i think thats for 2 ? ? ? ?
Old 06-03-07, 06:09 PM   #24
jonhunt
might get them slap them in and c.
also bro askin for new lights for his car so i get them for him.
jon
Old 31-07-07, 07:28 PM   #25
gazman
Hi all,
I'm looking to upgrade my headlights, after using the search, found many threads on the subject (including this one) A point that comes up regulaly is not to get too high a wattage, as I understand it the curvey headlight bulbs are 45/45w? I was looking at H4 12V 60/55W Philips Vision plus bulbs, does anyone know if these bulbs will be ok as the wattage is slightly higher
Thanks, Gaz
P.s; is it normal for the headlights to dull ever so slightly when i use my brake lights?
Old 12-08-07, 11:56 AM   #26
dyzio
dyzio's Avatar
Idiot question 1
will these fit?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300139815876
Idiot question 2
How to change the bulbs? Does the fairing need to be take off or the clocks or...
cheers
Old 12-08-07, 02:31 PM   #27
Ruffy
Ruffy's Avatar
This could be perfectly normal. I presume that you're checking this phenomenon while the bike's idling or off i.e. the alternators not putting out full charge. The extra loading of the brake lights could be enough to fractionally drop the effective voltage across the battery. The effect is made worse if using higher power bulbs with standard wiring (that is generally not fantastic on bikes, and some Suzuki's have a poor reputation on this aspect) due to increased volt drop in the wires. Try blipping the throttle and see if it makes a difference.
Being more pessemistic, it could also be symptomatic of the battery beginning to fail. All batteries have an internal resistance, which is why the terminal voltage changes with current. As the battery deteriorates, the plates in the battery begin to suplhate causing this internal resistance to increase, so the effect is magnified. Try to keep the battery charged using an Optimate, or similar, if you don't use the bike that often, and just keep an eye on it. If you're not seeing other electrical issues then it's probably not worth worrying about.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 12-08-07, 03:56 PM   #28
Viney
Originally Posted by dyziowg View Post
Idiot question 1
will these fit?
Idiot question 2
cheers
Yes they will fit, no you dont have to remove anything. They are fidly, but you can do them with everything in place.
I bought some of the Philips xtreme bulbs, and to be honest didnt notice ANY difference over the silverstars that i had fitted. However, i did notice a difference over the silverstars in the car?? Better reflector id expect, thats where they stayed.
Old 12-08-07, 04:20 PM   #29
gazman
Thanks Ruffy,
I think they've always done it & I've had the bike just over a year so I don't 'spose there's anything to worry about, & I dont seem to be having any problems with the vision plus that i put in.
dyziowg, they aren't difficult to fit, just a bit fiddly, it explains how in the Haynes manual. I found it easier to get to by moving the handlebars around a bit & also to have one hand going in over the top of the fairing & one hand coming up & underneath the fairing, (I hope this makes a bit more sense than I've managed to make it sound.)
Old 14-08-07, 06:48 PM   #30
Jools'SV Now
Just ordered the osram cool blue ones as well.
will let you know
1. how I get on
2. how different
3. was it wurf it ?
NEW HEADLIGHT BULBS Quiff Wichard Bikes - Talk & Issues 7 10-07-12 09:55 PM
Headlight bulbs melting neil.kemp SV Talk, Tuning & Tweaking 2 20-04-09 10:57 AM
lidl headlight bulbs hovis Bikes - Talk & Issues 9 05-06-07 03:14 PM
Swapping headlight bulbs Jase22 SV Talk, Tuning & Tweaking 11 21-12-05 12:33 AM
Headlight bulbs stick Bikes - Talk & Issues 2 27-02-05 09:42 PM
