Old 27-09-07, 01:06 PM   #21
andyb
Default Re: rearset Compatability
[quote=northwind;1298696] Are the discs early SRAD, the really thin ones that they stopped using?[/quote]
How do I find out, they are SRAD ones but what year I dont know. They have min thickness of 4.5mm stamped on them if that helps? On the Duc bars have you any idea how to attach the brake fluid reservoir?
Old 27-09-07, 06:36 PM   #22
Discs- no, not sure. 4.5mm seems like a sensible minimum, IIRC the early ones started out thinner but had the same minimums.
As for the reservoir- duck tape! Or alternatively, does the bar have a hole in the inside end? If it does, get a rubber bung in there, and bolt a mount to it, that's how mine's held on now (after a long spell with duck tape).
Old 27-09-07, 06:45 PM   #23
andyb
Can you explain a bit more about the reservoir, maybe a pic? I'm assuming drill a hole through the bar from the top, put a bar end rubber inside and screw the mount to that???
Old 27-09-07, 06:52 PM   #24
I dont have any pics of mine, I'll see what I can scratch up. Basically the end of the bar is open on my clipons, just like the outside end, so I mounted the reservoir in the same way that you'd fit bar-ends into hollow bars, with an expanding plug.
You could drill it, but they felt like steel, not easy to tap... Hmm. Maybe you could fly the reservoir off the master cylinder mounts?
Old 27-09-07, 07:02 PM   #25
andyb
Ahh so use an expanding plug then make up a bracket to mount the reservoir on?
Old 27-09-07, 07:41 PM   #26
21QUEST
21QUEST's Avatar
You have a PM
Ben
Nemo me impune lacessit.
Sat Nav Compatability gazza Bikes - Talk & Issues 2 14-07-08 04:10 PM
Rearset compatability question Baph SV Talk, Tuning & Tweaking 4 26-04-07 10:13 AM
Compatability (footpeg hanger) smurfbuds SV Talk, Tuning & Tweaking 4 30-03-07 02:29 PM
Standard zorst compatability chunkytfg SV Talk, Tuning & Tweaking 7 16-12-06 07:30 PM
Bandit wheel compatability svrash SV Talk, Tuning & Tweaking 1 17-09-06 11:11 AM
