Old 01-02-09, 11:58 AM   #301
Dave20046
Dave20046's Avatar
Default Re: Bent Banana - The SV resurrection.
Little bit more sealant on the bugger then
cool, will I need to scrape the old sealant off? And do you know how long it takes to set until I can run the engine again?
Old 01-02-09, 01:35 PM   #302
Dave20046
Dave20046's Avatar
Resealed the clutch cover. Snapped the ****ing rubber ring thing though while trying to clean it...ah well more sealant. I'm sure my torque wrench doesn't work I set it to 10nm but it just kept going until it got to the point I was scared I'd strip the threads.
Anyhoo, I was wrong there is a rubber oring on the filler cap I'll have to try get a replacement. There was also a lot of white gunge round it from moisture and oil mixing...is this right in an engine?
Could do with someone helping me find the flasher unit - can't find it anywhere! And it aint mentioned in the manuals
Dave
Old 01-02-09, 02:37 PM   #303
MattCollins
Dave,
Why are you buggerising (another technical term) around with silicon? Is there anything preventing the installation of real gaskets?
If you must build silicon gaskets, don't tighten them up straight away. Either let the (even) bead go off before fitting the cover (it'll squeeze down into the join) or let stand for 20-30min, fit, but pull it down just short of the silicon squeezing out of the join, allow to stand overnight then tighten. This gives the "gasket" a bit of substance and helps to avoid squeezing it out of the join and into the motor.
Old 01-02-09, 02:41 PM   #304
Dave20046
Dave20046's Avatar
Originally Posted by MattCo View Post
Dave,
Cheers matt, bit late for that but if I have to do it a 3rd time that'll be useful info! Cheers.
Old 01-02-09, 03:00 PM   #305
Dave20046
Dave20046's Avatar
Matt do you know how long I should leave it before putting oil back in/ starting the bike?
Old 01-02-09, 03:17 PM   #306
MattCollins
I usually like to leave these things overnight.
Old 01-02-09, 03:19 PM   #307
Dave20046
Dave20046's Avatar
Cheers mate, will do!
Old 01-02-09, 03:19 PM   #308
Alpinestarhero
Overnight is a good idea, i think the heat of the engine will help complete the curing process aswell.
Old 01-02-09, 05:06 PM   #309
Dave20046
Dave20046's Avatar
Found the final leak, gonna be a pain in the ****:- mid gasket on the rear cylinder. I think it was there before...might just ignore it
Old 01-02-09, 08:53 PM   #310
Dave20046
Dave20046's Avatar
I want a new bike
Bent rim! phil24_7 Bikes - Talk & Issues 18 01-11-07 02:51 PM
The worlds straightest banana gazman Photos 15 19-08-07 07:21 PM
Geostationary banana over texas philipMac Idle Banter 5 01-02-07 10:21 AM
2000 W reg naked tweaked banana for sale Sloth For Sale - SV's and SV related items 0 25-06-06 12:28 AM
Photos of my new VFR Banana... chutz Photos 28 03-09-05 01:52 PM
