#31 |
SV650 headlights as supplied to the UK use a H4 type bulb ... these are 2 bulbs in one shell ... one for dip, one for main ... so having one bulb instead of 2 makes no difference really
#32 |
i see.that makes sense.I just wasnt sure how rewiring would affect this
#33 |
It doesn't.
I've got a single light now, but theres 2 H4 connectors tucked in the headlight shell in case I fancy putting some dominator lights back on. (mine aren't from the S loom, but a H4 connector is a H4 connector)
#34 |
righto.atleast it doesnt sound too complicated.is it going to be possible to make the wires as tidy as they are on the nakeds?
#35 |
Yes, but you'll have to plan out exactly what wires need to go from the clocks to where.
As your clocks will probably have less wires than the standard ones then you have the chance of doing a very neat install. I'll tell you now though, mine's a disgrace, it just works.
#36 |
sounds like I might be giving it a go then.it all sounds do-able.since we're talking about mods, what easy options do I have when it comes to fitting a bigger back wheel to the sv?presumably the bandit of gsxr will be best suited?
thanks |
#37 |
Bandit 1200 is most common, do a search its been covered recently quite a lot
#38 |
excellent.thats another mod in the pipeline.]
just been looking at the sv and it seems that I would definitely have to drill the top yoke rather than replacing it, as the ignition is attached to the yoke.best crack the drill out when i start then. |
#39 |
It's not attatched, it's bolted, T40 security bit or you can knock the pin out of the middle of the bolt to use a normal T40 bit on it.
The GSXR SRAD yoke has same fitment (looks like can nick the switch bit and replace the lock barrell if i need a spare switch too)
#40 |
right. so you can I remove the top yoke without disturbing the ignition?
thanks as always for your replies.much appreciated |
NI Number talk | plowsie | Idle Banter | 77 | 16-07-08 07:01 AM |
Talk Talk | RhythmJunkie | Idle Banter | 5 | 15-08-07 11:00 PM |
Taking off the fairing on a 2002 SVS and converting it to look like a naked SV | tmillard | SV Talk, Tuning & Tweaking | 10 | 22-05-07 02:44 PM |
Will she talk to me? | JohnA | SV Talk, Tuning & Tweaking | 3 | 03-03-05 06:05 PM |
Torque Talk | Stan the Man | SV Talk, Tuning & Tweaking | 2 | 27-12-04 08:38 PM |
