#31 | |
#32 |
I saw a wee video of that (no hands) with an indicator on the yokes showing fork angle... Basically, when you move your weight to the inside of the planned turn, the movement "bends" the bike at the steering stem and the wheel turns towards the outside of the turn, ie, it effectively countersteers itself even though you're not touching the bars. If the forks weren't raked, it wouldn't work the same way. Sort of hard to explain, but if you imagine pushing a bike sideways at about the middle, then you can see that the bars will move as a result.
Still, it is possible to turn a bike with locked steering, Marc Gillespie used to do it as part of his stunt show, Kevin Carmichael's done it too. He hung himself right off the bike then pulled it on top of himself, basically just knocked it over, then rode it out and stood it back up. You couldn't use it on the road, I asked him about it once and he said the hard part isn't starting it turning- that's pretty easy once you get aggressive enough- it's stopping it from just falling over. Technically very hard, but it made for a rubbish looking stunt so he's stopped doing it. He said he offered to show Keith Code how to do it but never got an answer ![]()
#34 |
Luke, We're into semantics here mate.
Whether you use weight transfer to hinge the bike (which moves the bars) or use the bars to hinge the bike, the result is, the bike hinges, which makes it tip in one direction or the other. As explained earlier, you have to keep pressure on the bars to *continue* the turn but you can get the bike to tip in initially using your body, knees etc. Of course if you lock the steering the bike isn't going to hinge and thus, the bike isn't going to turn. Which sort of validates the above. Why did they need to lock the steering? Because if they hadn't, it would have turned the bike. QED really. I feel that's been explained as well as it can be and that there's not a lot more to add. Cheers, Carl |
#35 |
I think you will find its all voodoo
HTH ![]() |
#36 | |
TBH it may be the fact that they are newer and therefore less squared off than the ones on your previous bike. I put a new set (Pilot Power 2CTs) on mine recently and it caught me out a couple of times in the first few days as the bike turned so quickly i had to pick it back up a bit mid corner! Fine now though - just a case of getting used to the difference really. However - if time to adjust to the bike/tyres isn't helping with your cornering, then you could adjust the suspension slightly to stop it dropping in too quickly. Don't worry about the trackday, you can take things as slowly as you feel comfortable and then build up gradually. It should certainly help with your cornering! |
#37 | |
And like I say, it can still be done, it's just completely unlike how you would ride a bike.
#38 |
I also have a 07 daytona and know exacty what you mean, it feels like you fall in to the corner rather than turn once you reach a certain point. i also think it is due to the tyres and the fast turn in nature of the bike, im kinda getting used to it now but with my rear tyre near its end i am going to try the metz m3, as i have heard they are a more progressive tyre, also the stock tyres arent really suited for genral road rideing.
#39 | |
#40 | |
At what point... | the_lone_wolf | Idle Banter | 10 | 01-03-09 08:36 PM |
How dangerous is this.... | ooger | Idle Banter | 14 | 09-05-08 12:54 PM |
What is the point of......... | zedleppelin1981 | Idle Banter | 18 | 10-01-07 08:25 PM |
Is biking REALLY dangerous or only midly dangerous? | thor | Bikes - Talk & Issues | 68 | 25-04-05 07:36 AM |
What's the point here? | Thumpa | SV Talk, Tuning & Tweaking | 53 | 18-08-03 09:16 AM |
